Superb, Peter, excellent craftsmanshipA productive day:
The remaining 45 of the 150 double knees placed.
Sanded the deck with grid 800 and polished with the 3 blocks.
Then taped the waterways to provide them the final gray paint:
The viscosity of the paint also allowed me to close all the cracks around the stanchions. The white on the inside comes later.
Then apply the linseed oil to the deck:
But also the deck beams:
And I could also provide the entire inside with linseed oil:
With 2 more pictures showing the direction of the planking:
When this layer of linseed oil is well absorbed, touch up some spots and another layer so that the last few cracks are closed.
Then it is the turn of the upper construction of the bulwark.
I am thoroughly enjoying keeping up with your build log Peter, very fascinating. That said, I read War and Peace several years ago, and between you (101 pages) and Heinrich (135 pages) I feel you are both giving Tolstoy a good run for his money!As with the aft deck, I also have some old photos as a source of inspiration for the foredeck and the bowsprit:
Here I also put all the names that I mentioned in the parts overview.
It took some time before I could place the bowsprit. I was not satisfied with the first paint result and I took everything apart again, sanded it and then mounted it in place. Then carefully removed from the deck and sprayed.
Then mounted all brackets and eyes, carefully slid back into the deck openings and glued:
In my enthusiasm I had applied a little too many eyepins for the turnbuckels. On the bowsprit itself there will be 4: for the 2 Bobstays at the bottom and the 2 shrouds on either side. The Back ropes has the turnbuckles nearby the hull.
YQ mentions placing an eyelet for the later attachment of the Fore Stay. However, the old photo, the Saga and MS drawings show a bail that runs over the bowsprit and is attached to the deck with 2 eyes.
And Chapelle wrote a few pages about the Gammon. A jump bar that runs over the bowsprit and is secured to the keel beam.
I made them myself. On top of the Gammon a M 0.8 mm bold and nut. Still in stock from another model building period.
Forward view:
I made the applied fittings from brass wire and residual material from the etched parts. It stands out nicely when you apply this 'copper colour'. But I stay more or less in the style of the original BN and have it blackened. It is not completely black, but more or less 'tanned' with Ballistol "Buntmetall-färber. They also call it 'browning'. I also have a jar of "Schnell-Brünierung", but the applied layer quickly fell off.
Then I can now continue building the bulwark.
Thanxs, Heinrich. I was happy to build the first part on the deck. But looking forward to so many items …….That re-painted bowsprit now looks the part Peter. Weights, tape, clips, clamps - what would we do without them?
Thanxs, Mark. It took some time, with a nice result.Superb, Peter, excellent craftsmanship![]()
Wow, that I am, with Heinrich, part of this equation by you. You make me speechless, Mark!I am thoroughly enjoying keeping up with your build log Peter, very fascinating. That said, I read War and Peace several years ago, and between you (101 pages) and Heinrich (135 pages) I feel you are both giving Tolstoy a good run for his money!
I forgot to include Paul's Vasa, now on page 140! Keeping up with you guys leaves very little time for our own modelsThanxs, Mark. It took some time, with a nice result.
Thanxs Mark.Great piece of analysis Peter. When I read this I went to see how the pin-racks and chainplates had been configured on my AL model (even though I think AL have far more 'deviations' than YQ). The biggest difference when compared to picture no. 2 is the position of the pin-rack opposite the mainmast, which AL has in quite a similar position to drawing no. 3. I've included a couple of rather badly-taken (low light) photos of the position of the chainplates and pin-racks at the mainmast and foremast of my AL model. I tried to line up the shrouds on either side to give a reasonably accurate perpendicular view.
I don't think this will help much, but it may provide another point of comparison
Cheers, Mark
Thank you, Joe. I'm glad I can be of assistance.Peter thanks for sharing all of your great replies and instruction! And thanks on the box.
Thanxs, Henk. Yes it is spayable. I bought it years ago in a set of different colors together with the air-brush. I added a few drops of water on the amount of the air-brush cup.Looks very nice and sleek Peter
I didn't know that Schmincke is sprayable, did you have to dilute it?
Greeting
Henk
Thanxs, Johan. It took some time with glueing, re-glueing and re-glueing …… The spraying was quite exciting. Seams ..... chinks ....Awesome, just awesome...![]()
Well, Heinrich, what can I say ….. ThanxsAll's well that ends well and the end result is very "well"!
She looks beautiful Peter! Well done indeed!After fixing both pin rails, glued the Main rail back to the hull:
Then along the raised aft deck the Monkey board with the Monkey rail glued:
Which I had already taped and cut the outside of that board. Then everything was taped to spray with the air-brush.
I sprayed it with Schmincke Aero Cloror 28101, Supra white opaque. That will give a silky gloss result:
After removing all the tape, this showed up.
With on this side the blank wooden parts, provided with the first layer of linseed oil. And with the small made hawse pipe.
With the blue-black side:
With here also the smaller hawse pipe.
Which gives nice lines at the back:
A few minor tweaks here and there. But I am satisfied with this result.
The next step is the lines on the hull under the Main rail, the 'scroll' around the hawse pipes and adding the nameplates.
