**VIEW THREAD HERE** |
Not that I meant anything by this post, oh no...
No worries, I thought it was cool!Not that I meant anything by this post, oh no...![]()
I am also happy to see you back on the warf!Back to the NL… just started putting planks on the lower part of the hull. Not too worried about doing both sides at the same time. First, the keel is still very straight. Second, I kept a detailed log of every board so far, tapper width at each end and where to start the tapers.
The section I am working on now will be painted white to the water line. Then black above that to the bottom of the lowest wale. So I’m not even sure why I’m being so meticulous with these? I definitely have to on the stained section.
Pic…
It is perfectly done. It is not often, that a builder is planking like you (and me -old-time) only a layer of planking can be done without hast.Back to the NL… just started putting planks on the lower part of the hull. Not too worried about doing both sides at the same time. First, the keel is still very straight. Second, I kept a detailed log of every board so far, tapper width at each end and where to start the tapers.
Pic…
Ditto- Good to see you back on your NL Dean.Now I'm happy!
Thanks Grant!Ditto- Good to see you back on your NL Dean.
This is what I have been waiting for. BRAVO.Quick update, it was a busy week for me, thus only 6 boards went on. I am hoping to finish the last 8 boards to close the gap this weekend!
Ps - to avoid any waviness and a lot of extra sanding when doing a plank on bulkhead hull, I always clamp the new board to the previous board where needed to keep them level.
DittoI'll only be convinced that you're back in the swing with NL when I see our friendly lion lurking about![]()
He is currently overseeing the hull planking!I'll only be convinced that you're back in the swing with NL when I see our friendly lion lurking about![]()
