Bravo ! c'est une beau modèle !
Merci beaucoup, Bosco.Bravo ! c'est une beau modèle !
Really got to come up with a whole new set of superlatives, but lacking those; again this looks superb!Sometimes you have an idea in your head for a long time .......... and then you have to get it out.
With this support as a result:
I build my BN as a yard model and then she must also be displayed like this:
The uprights are secured to the connection with the beams with hex bolts. Will I soon be able to exhibit her at a meeting in the Netherlands.
Then the question may arise, why are the front and back not supported further. Keep this display stand in mind... --> Display Stand <--
Thanks, Johan. My inspiration was the ‘Hemerica on the slipway’ from Jan Blonk on the Dutch forum. Just the stand and not the weathering.Really got to come up with a whole new set of superlatives, but lacking those; again this looks superb!
At minimums this is all very inspirational.
Brilliant!Sometimes you have an idea in your head for a long time .......... and then you have to get it out.
Thanxs, Mark. It’s much appreciate.Brilliant!
Thanxs, Henk. After some adjustments I was also happy with it.Nicely done the standard Peter
Fits the model very well
Hi Etienne. Baie dankie vir jou besoek en die mooi woorde.Hi Peter, from Sout Africa, I am joining these acivities at late stage but hopefully will be able to see how you are doing with this kit. Love the way you have started the log, it feels like reading a good novel ...groet uit zuid afrika
Good morning Peter. I have nothing to say....Sometimes you have an idea in your head for a long time .......... and then you have to get it out.
Thanxs. Grant.Good morning Peter. I have nothing to say.........blown away by your work! Cheers Grant
Thanxs, Rob.Beautiful craftsmanship and imagination.
Thanks, Heinrich. The advantage of building slow is that you have all the time to consider your options of the pros and cons and eventually change them.Hi Peter. I fully agree that a removable roof would be the way to go - the end result, I am positive, will follow suit with the exquisite quality of the rest of the model.
Hi Uwe. Checked my e-mails a moment ago and saw the alert of your post.A beautiful way with the open and partly open houses, also the wheel house
only one fast comment, about a small mistake, which "jumped" immediately into my eye, when I opend your post
Here the cross / stiffener is not fitting
or you will add also such a barrel ?
