Hallo Jimsky.Karl, The POF stands for Plank On Fame model (you will show the frames assembly, like Georgian style), POB is Plank On Bullhead (instead of frames, you will use bulkheads and no internal structure, cover the hull with planks)
Karl, The POF steht für Plank On Fame model (du zeigst die Spantmontage, wie im georgianischen Stil), POB ist Plank On Bullhead (anstelle von Spanten verwendest du Schotts und keine interne Struktur, bedecke den Rumpf mit Planken)
Hi, thanks for the kind words. BTW, I'm located in Hackettstown, NJ.Looking great. I think Igor’s method makes a lot of sense too. Using staples to attach the planks I’m not sure about though. Your gun deck will be included I take it ?
One of the symptoms of OCD is perfection.in my OCD way
The crazy thing about it is, I only get into this mode when addressing mundane repetitive tasks. Sometimes it results in errors and small "re-dos". The nature of the beast. Also, my loving Admiral knows not to interrupt me during these Spurts as it causes me to lose focus and I have trouble picking back up where I left off.
Yes, Stephan, perfection is one component. I do have OCD behaviors. Keep in mind you don't need to exhibit all of them. The relevant behaviors for me are in bold below. This is not a complete list. It's just a few I copied off a site to share what I deal with. Part of dealing with these is to actually challenge your self to face them. Dealing with ambiguity is the one I face most when building models as there are many uncertainties. Conversely, "Fear of contamination or dirt" and "Washing and cleaning" I don't have. The Admiral always makes fun, "Why couldn't you have the ones that would help me with the cleaning of the house!" I do of course, she just likes to tease.One of the symptoms of OCD is perfection.
I think it can then be attributed to the way you apply the Vaseline.
But, your fast, that's for sure. I would get made in my head seeing all these gaps. But I'm sure with the next layer everything will be okay. I see this method before with these nails. We keep watching
Is it "Phil"? Yes, Ancre. It's in the thread's title.I haven’t seen Igor’s method other than on his site. You’re working off Ancre plans I guess ? I thinking you may have issues with the total size of the hull being larger than the plans so you may not be able to use the plans for measurements later on. The second layer will be what planks again ? Also could your frames be thicker ?
It’s Tony, Phillip is my middle. Yes good planning on your part indeed. Looking forward to watching your progress.Is it "Phil"? Yes, Ancre. It's in the thread's title.If you go back to the first few posts where I share my planning, you'll see I reduced the Frames' plan by the amount of the width of the 3 layers of planks, plus a % tolerance for sanding. I will error in being over, with the knowledge it is easier to sand off any overages.
I will take internal hull measurements long before any internal structures are added.
I'm sure I may have forgotten something. but after 8 months of planning, I should have considered the critical items.
Thanks for sharing those points of interest! They certainly are legit!
Cheers.
