Syren 1803 1:64 Model Shipways
Now how on earth did I miss this posting? :(
Roger, the deck planking is absolutely superb! It looks incredibly rich in color and warm in ambience while at the same time maintaining razor sharp seams between the planks. In combination with the red hue of the inner bulwarks it looks simply exquisite. This is going to be one heck of a beautiful Syren! Kudos, my friend!
I think it’s time for an update even though it doesn’t look like much progress.
I am finding the deck, especially nibblng and joggling, very time consuming. The absence of a false deck has also made things significantly more difficult, especially where the plank butts fall. I mentioned in my post #278 that a false deck fitted at this stage would have altered critical heights for other parts of the construction. Another lesson learned for future models but that is how we gain experience. Also, I previously mentioned my deck pattern butt ends would loosely follow that of the model designer as shown in his manual. In other words every fourth bulkhead, not technically correct but I think it’s turning out ok.
As I lay the pear planks I am making sure the margin planks are removable. Trying to cut them in place just will not work for me. That meant cutting and dry fitting the plank ends and the margin very carefully trying to get a neat fit. Measure, cut, scribe, curse, redo, fit, cut, curse, sand, fit, curse, redo - well you get the idea :D.
Once I had completed the joggled planks to the point I no longer needed to remove the margin plank/s for cutting I started glueing things down. In the photo the port side is partly glued and underway. The stb’d side is next but for the photo I showed the planks and margin plank on that side loose and being prepared. Once I have completed the necessary joggling that side too will be glued. The gaps between deck planks will, hopefully, be made more consistent later.
I know recommendations are to alternate the laying of planking port and stb’d. However, I decided to mostly complete the port side then work on the stb’d side. My thinking is I can adjust plank widths to stb’d so my plank count is equal each side from the centerline and hopefully my butt pattern too. It remains to be seen but if I mess up it will be blamed in good sea going fashion on the apprentice :).
So back to the bench for me this afternoon. Thanks to those of you who follow my slow progress, your helpful input, likes and laughs are always well appreciated.
Good morning Roger. Your joggle and nibble joints may have been time consuming however they came out perfectly- false deck or not. I can see why you had to make the but joints match the bulkhead with no false deck. I like the clean look of the deck and I hope you will not change the pear wood colour too much when finishing it? It is beautiful. Cheers Grant
Heinrich, I honestly don’t know how you are able to follow, support, advise and comment on so many logs. Then on top of that you not only teach but also build those exquisite ship models.
I am actually enjoying laying the pear deck but looking forward to completing it. We have discussed the type of finish elsewhere but I think it may be advisable for me to do that before the next steps in the build. That way I can protect the decking to a certain extent.
Thank you again for giving me such a supportive boost as I progress.
It is a huge pleasure my friend!
Hi Grant, thanks for the kind words and observations. The lack of a false deck has indeed caused me some issues. I will never construct another ship without ensuring I plan for and lay a false deck. Those basswood blocks I laid between the bulkheads were not intended to be dead level so are no help now as I lay the deck planks. As you note the butts deliberately lay on the bulkheads but where they dangle in the breeze next to the margin I will/am providing additional support if possible. As to wood colour I intend using tung oil hoping the natural pear wood will not darken too much. I deliberately cut planks from different billets, mixed the planks up and then laid them. That way they don’t run in lines of the same shade or grain pattern. Mind you there’s not much grain showing, which I try to avoid. Thanks again for your support.
At last my deck is laid, which seemed to go on forever. I had to redo many of the pear planks in an attempt to get an even thickness across the deck, while still allowing for slight camber. It was not to be though because, as previously mentioned, not having a false deck introduced a lot more inconsistencies as work progressed. I always try to work through problems but sometimes have to accept limitations. Anyway, I reached a point where I had to be satisfied with my efforts otherwise I would end up redoing my previous redos of the redos that were redone ROTF.
As I worked across the deck I adjusted the width of some lines of planks on the stb’d side. The width adjustment was slight but it meant I could try to get that symmetrical butt pattern port and stb’d. It mostly worked out and I feel any visual discrepancies will eventually be covered by deck clutter, I hope.
One problem I did encounter was not planning for where the margin scarph joints lay. As I completed the planking I realised that the last plank each side, next to the margins, would end with butts adjacent to those margin scarphs. A weak point no doubt so I adjusted the last plank each side to extend the butt joint beyond the scarph. That meant increasing the width of the plank to about 15” real scale to avoid pointy plank ends where joggling would not work. I had to then cut a lengthwise notch to allow it to fit across a plank width and most of the next one. Realistic? I’m not sure but I reckon it is practical, maybe. I added a marked up photo to try to show what I mean. What is it they say? - “a picture is worth a thousand words”. Well, mine anyway :).
So next is deck scraping, fitting the waterway and then experimentation with a deck finish on scrap pear wood and possibly simulated plank fastenings. I have some ideas gleaned from knowledgable modellers so it will depend on how small I can make the simulated treenail “spots”, if at all.
Thanks for taking your valuable time to follow my posts, it’s much appreciated.
Just beautiful work here Roger. Congratulations on this milestone.
Thank you so much Paul. It’s interesting isn’t it, as we move forward with our builds how the milestones shift as we progress. Firstly the hull planking, then the deck, the complicated small stuff, the rigging, those never ending clove hitches and so on. To be honest I continue to be inspired by your Vasa build, a continuous milestone of artwork.
View attachment 334044View attachment 334045
Good morning Roger. The deck came out brilliantly- with no false deck and many butt (the butt pattern at the bow is magic) and scarph joints this was no easy feat. Awesome worth. Cheers Grant
Your deck looks truly beautiful, Roger! The color of the planks matches superbly, and your nibbing adds another dimension to the visual aspect.
Thanks Heinrich, I’m pleased how the randomness of the plank colours worked out. Cutting plank lengths off the side of 1/8” thick pear sheets provided those colour variations while minimizing grain patterns. As for the nibbing - well I think I have found a new form of workshop therapy :D.
Dear Roger
Your deck looks beautiful, you are doing wonderful work here . Congratulations on this milestone Okay :)
Thanks, I appreciate your input and support Shota. Now the deck is finished I am looking forward to planning the deck fixtures and fittings. However, there’s also the hull copper plating that is waiting - yikes, another form of model ship therapy :).
Such clean workmanship on the deck. Thumbs-Up
Hi Kurt, it was a slow process for me but I have read that quite a few other modellers say deck planking takes a while. So now I am going to work on mock ups for deck treenails. If I try to get them to scale I suspect they will hardly show on the deck planks, which means I’ll forego them. Your comment and support is very welcome, thanks.
Hi Grant, thanks!
I cannot tell you how many curse words were hanging in the air as work progressed though ROTF. My biggest concern was messing up the nibbing/joggling on those pear margin pieces. I have learned what works and does not work for a future build so it’s all good experience.
No doubt the longest period for me without an update but family matters have taken priority. Hopefully progress will pick up again soon.
I laid the hull aside for a while and leafed through the build manual for an achievable small item to build in the meantime. I chose the Syren longboat but as I’ve now read in other threads these little boats can be fiddly.
The lift method is used for the longboat and all the laser cut parts are provided for in the kit. I started out using the supplied sheet basswood but then wondered if I could manage with pear. Don’t ask me why :D.
I cut new pear lifts with a scroll saw using the plan patterns, glued them up and went at it with a range of Dremel cutters, burrs, files and sandpaper. Much more difficult than I had anticipated but I’ll keep at it to see what is personally achievable. At the moment it looks like a pregnant dugout canoe. If it doesn’t work out there will be a Viking funeral ROTF.
Thanks again for following my log. Work continues, but slowly.
