It looks nice but ‘complex’ Ronald.Another update..... I have now added a part of the stern, see photos....
Yes Peter, it is.... I am in doubt what to do with this.... I think I can correct a lot, and a lot will not even be visible later on, but I am not sure of the consequences when I do not correct this difference...It looks nice but ‘complex’ Ronald.
Unfortunately, it no longer fits like a glove...
When placing the horizontal parts, the first part did not fit properly, see below:View attachment 334824
It seems that the drawing is not correct, moving it to the back didn't seem an option either because I had made the parts exactly according to the drawing, and the shape of the beam seemed to be exactly right with the 'rabbit', the notch where the planks come in to fall. I thought, mistake, and made another...
On the left the existing one, on the right the 'corrected'...
Placed the corrected one, and the other beams also placed and glued.
Result:
I thought, solved.... Then placed the vertical part:
And here I found out that the first beam was correct, it doesn't fit well on the vertical beam, but I thought: I'm not going to remove everything for that, I can shape the outside well, only the inside is not completely correct. I can fix this later with shims, or put planks over it. Not worth demolishing everything again. This was mistake number 2. What I didn't notice, or at least didn't understand the consequences of this, was that the vertical beam stood too far forward....
It makes a difference of 3 to 4 mm. However, this photo also shows that the top beam is correctly placed on the keel when you look at the notch in it and the shape of the beam....
I glued everything together, it was well put together, and I thought that demolishing and reassembling would not lead to a better result (I told myself that).
I made the next mistake, the fitting of the last frame:
But now I'm faced with a dilemma.... 3 to 4 mm is quite a lot looking at what is yet to come. When I want to fix this, assuming that everything goes well, I have to renew everything up to the replacement of the last frame. I don't know exactly where I went wrong though, looking at:
It seems that placing everything back is also causing problems.....
That’s what I meant whit ‘complex’! Hopefully the drawing are right and you can find where it ‘hurts / wringt’.Yes Peter, it is.... I am in doubt what to do with this.... I think I can correct a lot, and a lot will not even be visible later on, but I am not sure of the consequences when I do not correct this difference...
Thank you for the trouble to study the photos! I am not sure what you mean though...That would be a possibility if I still had to make the horizontal beams, but they have already been fixed...I spent quite a long time looking at your pictures to see what was wrong. Hard to perceive this. But as you say, this could be a solution. What you can then also do is at the touch points where that rear meets the frames. There on the horizontal beams outward and inward give some more meat. You sand that flush with the frames afterwards.
Ik heb best lang naar je foto's gekeken om te zien wat er mis was. Moeilijk om dit waar te kunnen nemen. Maar zoals je zegt kan dit een oplossing zijn. Wat je dan ook kan doen is op de raakpunten waar die achterzijde de frames raakt. Daar op de horizontale balken naar buiten en naar binnen wat meer vlees te geven. Dat schuur je naderhand gelijk met de frames.
Hi Maarten, a while ago you asked for a stack of frames. I couldn't show it at the time, but now I canHi Ronald,
Maybe for you boring but for us not. We want to see some pictures of your huge stack of frames.![]()
Hi Bernard,Hello,
I made this stern almost 10 years ago. I had previously modeled it in 3D. It is a very difficult area to assemble because of the different angles between the parts. To build it I made a template that allowed me to do it without any problem.
There are no drawing errors, all the parts have to be made very precisely.View attachment 334918
Bernard
Now that's what I would call a full stack!Hi Maarten, a while ago you asked for a stack of frames. I couldn't show it at the time, but now I can
Like mentioned earlier, I will start to fix the frames on the keel. First I do a final check comparing it to the drawings to see if the shape is still exactly als drawn, then I will, if applicable, add some markings like where the deckframes will be, then a final check if the frame is at the desired position on the frame whereafter I add spacers and glue the frame to the keel....
Then it's to late. I ment to let them stick out on the outside and inside.Thank you for the trouble to study the photos! I am not sure what you mean though...That would be a possibility if I still had to make the horizontal beams, but they have already been fixed...
Hallo Bernard,Hello,
Bernard
Very impressive - and very accurate production of these frames - Bravo!!!!Hi Maarten, a while ago you asked for a stack of frames. I couldn't show it at the time, but now I can
Hello Ronald, I'm sorry, I can't understand (translation), what's the problem with your model, ThanksHi Maarten, a while ago you asked for a stack of frames. I couldn't show it at the time, but now I can
