Each of us has his\her own acceptance level...there is no right or wrong, as long as you like it!
**VIEW THREAD HERE** |
Ha Shota,good evening dear friends
In the last few days I produced a third burn head with an inner diameter of 0.67 mm and an outer diameter of 0.9 mm.
View attachment 342505View attachment 342506View attachment 342507
Today I went to perform the experiment of the new burning head. This time I also changed the temperature of the soldering iron. In the previous attempts I burned at 400 degrees Celsius, today I went down to 375 to refine the burn mark.
I am attaching the results of my experiments In the first you can see in the wide panel the three attempts 1, 0.5 and 0.67 and above it in the narrow panel 0.5 and 0.67.
And in the second picture the narrow panel is all 0.67 internal radius.
After the three attempts, I tend to use the new plates I made with the 0.67mm burner. I would love to hear your opinion.
My intention is to remove the boxwood panels, make new ones, glue and burn again.
I understand that I am in a bit of a hurry in the construction progress and that I should examine the possibilities of improving the products before installation/gluing.
Happy Thanksgiving and a pleasant and enjoyable weekend to all of us![]()
Hi Shota,
I appreciate your perseverance! I do like the smaller trunnels at this scale. But don't miss Maarten's note about sanding. I felt like my burned-in trunnels were distractingly prominent until I sanded off some of the burn marks. I also didn't put as many because scale modeling (in my opinion) can't always fully replicate the full-size ship.
You're going to be a master-builder one day my friend!
thank you very much my dear friends,Ha Shota,
Lovely, just lovely. The sanding aside, see @dockattner suggestion, I would personally opt for the 0,5mm and the lower temp settings.
I also would convince myself which option I prefer, before demolishing the ship...
thanks for your attention, my Dear friendSteady improvement Shota, looks very good, however you need to do one more here and then it will be perfect.
Thank you very much dear friendsMuch better now
Good to have eagles´s eye Tobias in our group -> I am also happy for such small hints
thank you very much my dear friendThis looks a 100% better, Shota and these wales also fit better than the first ones.
Wow, I assume you've sanded it now too. Looks great even though I agree with Jim, but I have to say great.Thank you very much dear friends![]()
for your attention and compliments.
the blank marking has been completed
Good morning Shota- yes I agree with you- you may be well satisfied. Cheers Grantgood evening dear friends
Today I dedicated several hours to make the wale again. I handled with the boxwood boards as well as the black painted board.
First I sanded all the black paint and then the burn marks on the boxwood panels. It became clear to me that I did not make a deep burn and with a light sanding I made the big burns disappear. I sanded and smoothed the surface of the three rows of boards to a uniform height.
View attachment 342628View attachment 342629
I repainted the wide black board with three coats of acrylic paint.
View attachment 342630View attachment 342631
Later I made the burns with the head of 0.67 mm internal diameter. This time I lowered the burning temperature to 360 degrees. Then I sanded the surface of the burn with fine sandpaper and applied a layer of bees wax.
View attachment 342632View attachment 342633View attachment 342634View attachment 342635
I am satisfied with the result that I achieved with your help Dearfriends, Good night![]()
