- Apr 20, 2020
thank you very much for your support and complimentsYour doing great with those improvements. I would choose two first liners over any POF. Huge respect for you
my dear friend's. I wish for all of us Peace in the whole world and among people, happiness for us and our family members and continued enjoyment of our hobbies.
I took a wooden board and on it I glued the boards using double-sided glue, the truth is that I saw the idea in one of the construction journals here on our websiteImpressive production here Shota! I can't see well - but did you create a jig for cutting the rabbet for the clinkering? How is the strip held in place?
my dear friendHi Shota. I understand that you used boxwood for the wales, but may I ask why you are not using the kit-supplied pear strips for planking?
Thank you, Shota. That's an excellent approach. I'm grateful for the opportunity to learn from you.I took a wooden board and on it I glued the boards using double-sided glue, the truth is that I saw the idea in one of the construction journals here on our website![]()
I may look for copper wire in the thickness of the cells because brass is a difficult material to drill.
Thank you very much for the kind words and the a advice, I have not yet decided which method to use.Great work Shota Wishing you a happy new year Sir, just a hint you may want to make a couple of wider boards for the planking at the stern, it makes life much easier to line the boards as you go higher up. Unless you adding triangular filler planks that is.
Dear friend, I would appreciate it if you could show me in the picture what is meant by the mistake in klinker and how to correct it, also here the illustration in the picture will help me correct and learnHi Shota,
there's a small mistake in your klinker planking. At the stem and stern the planking ends craweel and not klinker.
Hi Shota,Dear friend, I would appreciate it if you could show me in the picture what is meant by the mistake in klinker and how to correct it, also here the illustration in the picture will help me correct and learn
Hi Shota!
Here is another picture of the transition of the clinker to the carweell planking at the bow and stern. The transition is difficult to make, especially on the boat of the ship.
Best regards
Thomas
Thank you, Paul. Maarten shows exactly how it should look.
my dear friend'sHi Shota,
I hope you and Christian won't mind if I jump in with some help. Just like on my esping the clinker planking fades out at the bow and stern. Here is a link to @Maarten's build report when he was completing this stage.
Start here and then view several postings in succession: https://shipsofscale.com/sosforums/threads/hms-alert-by-maarten.6097/post-152325
I hope this helps!
