DE 7 PROVINCIËN (1665) 1:50
I have been working on planking the deck. The easy part has been done, the lines of straight planks. Individual planks have been made to fit from centre to centre of the deckbeams. No particular planking system is kept as the Dutch did use whatever was available. I did mirror left and right though.
The caulking is simulated by painting the sides of the planks with a chocolate brown acrylic marker, great idea copied from Nigel @NMBROOK. I also tried some black paper, but that looked too prominent to my taste. When oiled it stands out a bit more.
Please bear in mind that the deck still has to be scraped flat. I will do that as soon as all deck planking (without the waterways, that will run slightly upwards) is finished.
Very nice work Herman. I used to think black tissue paper caulking looked great with Pear, but my tastes have changed over the years.Brown is subtle and blends, not jars against the tones of the wood;)
Kind Regards
Nigel
Thank you Nigel, much appreciated.
I completely agree with you, hence me following your example.
As I had no experience in modeling I study the building logs on this forum (and my expanding library) and only then proceed with the next step.
I am with 100% certainty not the fastest here, but luckily it is not a competition. All about the journey and trying to reach the best possible result for me.
I am grateful for you, and everyone here, sharing your experience.
Beautiful deck planking Herman. Are you planning on simulating the schaarstokken?
Thank you Heinrich.
As per the drawings of Otte Blom I will keep the planking around the gratings level on this deck. In hindsight it might have looked better to make the line of planking on both sides of the gratings from the slightly darker pearwood. I do plan to make a sligtly raised deck-planking around the mast-transits / under the capstan and the kolderstok-control from pearwood.
Hi Herman. The planking with this caulking looks beautiful and subtle. The mirrored pattern gives a kind of feeling of balanc.
Bedankt Maarten
Ik woon in Spijkenisse, in de buurt van Rotterdam, dus beide 'Fijnhouthandels' zijn een optie. Half april heb ik een paar dagen vrij en misschien ga ik er een bezoeken, anders bestel ik bij Dictum. geschutpoorten en voordat het daadwerkelijke beplanken begint moet ik nog trappen maken en een bediende, dus half april komt mooi op tijd.
Hallo Herman,
Bijlage aan het doornemen. Ik wil je graag nog een goed adres doorgeven.
Met groet,
Homme Korstanje
Ik heb 8 jaar in Capelle gewoond maar ken geen speciaalzaak in de omgeving van Rotterdam. Als je naar Arnhem gaat zou ik zeker aanraden om ook langs te gaan bij Baptist, de snoepwinkel voor iedere houtbewerker.
Als je naar de Arnhemse fijhouthandel gaat en ook nog een bezoekje gaat brengen aan Baptist, vergeet je dan niet te realiseren dat dit peperdure uitgaven worden. Ik ging vroeger bij houthandel vd Stad in zaandam langs. Die hadden toen een zogenaamde rest/afval container staan. Daar kon je zeer goedkoop stukken hout verkrijgen. Verder kan ik je .. zach en hardhout in Loenen adviseren. Heeft soms verrassend hout in voorraad. Succes er mee!
Groet
Homme Korstanje
I had not seen hatches treated like this before. Thank you for sharing; always more to learn here.
Het meerendeel van mijn nieuwe gereedschappen komen daar vandaan. Verder veel oude gereedschappen in de loop der jaren gekocht en gekregen.
groet
Homme
I prefer to purchase my tools second-hand when available and in good condition at the time I need them.
Otherwise new. Most of my Proxxon tools are bought from Magazijnblijdorp because I like their quick and excellent service. Additonal benefit for Proxxon is the fact the importer is situated in my home town. Last week my bandsaw died on me and the next morning I could exchange this saw for a new one under guarantee.
But the shop you mentioned might come in handy when I need some mini chisels/gouges or a miniscraper..
