Beautiful, crisp work, Herman, and a belated Happy Birthday
I hope it was a good one!
Very nice work Herman. I used to think black tissue paper caulking looked great with Pear, but my tastes have changed over the years.Brown is subtle and blends, not jars against the tones of the wood
Kind Regards
Nigel
Thanks Paul, much appreciated certainly coming from you. With your true masterpiece first build you have set a high standard. No pressure, but a very good example and for me something to aim for.Truly beautiful work Herman! This is a great start to a perfect deck!
Hi Herman. The planking with this caulking looks beautiful and subtle. The mirrored pattern gives a kind of feeling of balanc.I have been working on planking the deck. The easy part has been done, the lines of straight planks. Individual planks have been made to fit from centre to centre of the deckbeams. No particular planking system is kept as the Dutch did use whatever was available. I did mirror left and right though.
The caulking is simulated by painting the sides of the planks with a chocolate brown acrylic marker, great idea copied from Nigel @NMBROOK. I also tried some black paper, but that looked too prominent to my taste. When oiled it stands out a bit more.
Please bear in mind that the deck still has to be scraped flat. I will do that as soon as all deck planking (without the waterways, that will run slightly upwards) is finished.
Hallo Herman,Bedankt Maarten
Ik woon in Spijkenisse, in de buurt van Rotterdam, dus beide 'Fijnhouthandels' zijn een optie. Half april heb ik een paar dagen vrij en misschien ga ik er een bezoeken, anders bestel ik bij Dictum. geschutpoorten en voordat het daadwerkelijke beplanken begint moet ik nog trappen maken en een bediende, dus half april komt mooi op tijd.
Ik heb 8 jaar in Capelle gewoond maar ken geen speciaalzaak in de omgeving van Rotterdam. Als je naar Arnhem gaat zou ik zeker aanraden om ook langs te gaan bij Baptist, de snoepwinkel voor iedere houtbewerker.
Baptist
Baptist Arnhem, het ruimste assortiment houtbewerkingsgereedschap- en machines, leverbaar uit voorraad. Deskundig advies. Bestel online of kom langs!baptist.nl
Thank you Homme.Hallo Herman,
Bijlage aan het doornemen. Ik wil je graag nog een goed adres doorgeven.
Met groet,![]()
Dieter Schmid Feine Werkzeuge – Ihr Shop für Holzwerkzeuge
Große Auswahl an Premium-Holz-Werkzeugen (Sägen, Hobel, Fräswerkzeuge & mehr) kombiniert mit kompetenter Beratung und persönlichem Service. Jetzt entdecken & direkt online bestellen.www.fine-tools.com
Homme Korstanje
Het meerendeel van mijn nieuwe gereedschappen komen daar vandaan. Verder veel oude gereedschappen in de loop der jaren gekocht en gekregen.Dankjewel Homme.
Dat schijnt een leuke gereedschapswinkel te zijn.
Well, that didn't work out very well, now did it? ;PThe upper deck of Vasa had a coaming most probably to avoid larger quantities of water going down at the lower decks.
I had not seen hatches treated like this before. Thank you for sharing; always more to learn here.
I prefer to purchase my tools second-hand when available and in good condition at the time I need them.Het meerendeel van mijn nieuwe gereedschappen komen daar vandaan. Verder veel oude gereedschappen in de loop der jaren gekocht en gekregen.
groet
Homme
My pleasure @Brewbararian. We all learn a lot from each other on this forum. I am happy to be of assistance for you.I had not seen hatches treated like this before. Thank you for sharing; always more to learn here.
