Hohenzollernmodell 1660-1670 Scale 1/75 POF build by Stephan Kertész (Steef66)
@Peter Voogt Thanks, nice to see you around here. No nothing to stop me.
And everybody else thanks for the likes and visit.
Today the rabbet.
Little tutorial how I do it.
First, I mark the rabbet line with pencil and for that I use a piece of wood along a board. The piece of wood indicates where the pencil line will be.
Note! This is a keel of a Dutch ship. It is not straightforward. So to make a construction in my Proxxon milling machine is not possible. It has to be done by hand and this is also a nice tutorial for those who do not have a milling machine.
So back to the line, see picture how this looks.
After applying the pencil line, I go over this pencil line to cut one in with a knife. Sometimes I can use a ruler, but in the curves I have to do this freehand.
Do not cut too deep, it is only meant as a mark and as a guide for the cutter.
In my handdril I use this cutter. That I can hold along the keel with my finger and cut a small line in the keel on the place of the line I cut before.
When this is done, I take another cutter, a cone shape.
I use this to go deeper in the rabbet line.
BUT TAKE ATTENTION
Only move the cutter in forward movement. Don't pull it back in the wood. And don't let the tip go in the wood. Only thit way makes a smooth slot. Pulling it back it will change direction and don't follow the line you make first.
Here a picture with an arrow how to move
I always start with the smallest cutters I have. 0,9 mm tip is the best for this job. On a high speed it won't catch in the wood. And keep in mind, don't use force, just let the cutter do the job.
0,9 mm is some times to small for the rabbet, if you need a wider rabbet you take the next cone shape cutter. like a 1,2 mm.
Take small steps with the cutters till you get the width you need on your rabbet. After that is done you go for the max. depth and smoothing the cut. I use the drop shape cutter for this. Note use the thickness of the last use cone for this job. In my case a 1,2 mm. drop shape cutter.
And this one is one of my favourite cutters, you can move this one for and backwards in the rabbet line.
Finish of with a piece of sandpaper to smooth it out.
End result:
View attachment 360610View attachment 360611View attachment 360612View attachment 360613
When I'm done on both sides I show you the end result.
Thanks for visiting my build report. :)
Thank you for that tutorial. I always learn much from you and your excellent and ingenious work. Cheers
I like it! Learn and make it. This is the perfect routine.
Thanks Jim.
Like a few others around here I started modeling 4 years ago, with just a few tools. I remember cutting parts out of plywood with a Stanley knife. Everyday I learn something new about wood and metal. How to use it.
Thats looking great. :)
Thanks Bryan, nice to see you around here.
Very nice result, Stephen. Very interesting manufacture of your rudder hanger fittings. Good work
Thanks Tobias, we learn from eachother. Always nice when someone shows how it was done. I don't have much money to spend, so always searching to cheap sources. I could buy a brass pipe and make the irons out of them. But this was in my drawer lying around.
Thanks ConstNZ for visiting and your kind words. I'm Glad, I could share my findings here and be helpfull to improve ourselfs.
Hi Stephan,
It looks great. I was already suprized you put on the lower pintle already. This as you still have to add the planking first and the lower pintle will be positioned on top of this.
I see you removed it again.
Hi Stephan,
Pintle! Nice word.
Was dry fit, building in this way it is almost playing chess. You have to think a few moves in front.
This moment I'm working on the stern frame. Difficult level 9...
And I'm planning the strake board and tingle. Also level 9.
Ouch...this should hurt unless the plywood is really relatively thin. I also remember all the tools I was using since I started my hobby. The knife I made myself from a commercial hacksaw, is still with me. I don't use it those days. In Russia, we called that type of knife - kosyachock. I removed the electric tape used as the handle, it was very old and sticky.
Guess today, you have a plethora of knives to choose from, styles, and sizes. Below is my 'Kosyachok'
Looks like a kiridashi. I like this one.
Very,very nice work Stephan !
Being unfamiliar with Dutch ship design, I have one question. On the horizontal keel Scarphs, are the three horizontal bolts in the join designed to act in the same way a hooked Scarph would work? By that, I mean reduce sheer stress on the joints vertical bolts
Kind Regards
Nigel
Kind Regards
Nigel
Thanks Nigel for your visit, all the likes and nice comment.
To your question, these are made in the joint to avoid leaking water through the joint from below the keel. Something to do with movement in the joint on rough sea.
I work since yesterday on the stern. In POF build one of the difficult things to make. Especially on a Dutch 2-decker. Lots of different angles and rounded parts. Nothing is straight on.
This is the part I'm constructing
I'm making the drawings in AutoCAD and print them with acrobat reader.
I use my Thickness sander a lot at the moment. Love this tool. I can make a piece of wood with a thickness of 0,01 accuracy.
First cut all the parts out
Then I glued the Fashion piece and the 'Broekstuk' (no English name for this one) together. And paste it to the right position on the stern post. After that I sanded the angle of the hull in it. After that I started to make the first Transom on it.
Short update of an immense lot of work. sometimes I use machinery to saw or sand, but most of it is done by hand, sanding, cutting and with a Japanese handsaw (spoiler alert.... no, no, not cutting ships in half) :cool:
Hi Stephan,
a very interesting and instructive construction report.
Also a very precise and neat work.
Thanks for sharing.
Hi Johann, thanks for visiting my build report and the kind words. To receive a compliment from a talented builder like you is always a great moment. Which only strengthens the motivation to continue.
Kind Regards
Nigel
Hi Nigel,
These are not bolts or treenails but plugs.
As Stephan said these are used to close the scarph joint from water seeping in.
In the scraph joint holes were drilled, these were stuffed with moss. Then the holes were plugged with small round kegs. The moss expanded and the scarph joint is closed avoinding seepage through the joints.
Hi Nigel,
Hi Maarten
Moss, well I learn something new every dayo_O
Kind Regards
Nigel
