Thank you for that tutorial. I always learn much from you and your excellent and ingenious work. Cheers@Peter Voogt Thanks, nice to see you around here. No nothing to stop me.
And everybody else thanks for the likes and visit.
Today the rabbet.
Little tutorial how I do it.
First, I mark the rabbet line with pencil and for that I use a piece of wood along a board. The piece of wood indicates where the pencil line will be.
Note! This is a keel of a Dutch ship. It is not straightforward. So to make a construction in my Proxxon milling machine is not possible. It has to be done by hand and this is also a nice tutorial for those who do not have a milling machine.
So back to the line, see picture how this looks.
After applying the pencil line, I go over this pencil line to cut one in with a knife. Sometimes I can use a ruler, but in the curves I have to do this freehand.
Do not cut too deep, it is only meant as a mark and as a guide for the cutter.
In my handdril I use this cutter. That I can hold along the keel with my finger and cut a small line in the keel on the place of the line I cut before.
When this is done, I take another cutter, a cone shape.
I use this to go deeper in the rabbet line.
BUT TAKE ATTENTION
Only move the cutter in forward movement. Don't pull it back in the wood. And don't let the tip go in the wood. Only thit way makes a smooth slot. Pulling it back it will change direction and don't follow the line you make first.
Here a picture with an arrow how to move
I always start with the smallest cutters I have. 0,9 mm tip is the best for this job. On a high speed it won't catch in the wood. And keep in mind, don't use force, just let the cutter do the job.
0,9 mm is some times to small for the rabbet, if you need a wider rabbet you take the next cone shape cutter. like a 1,2 mm.
Take small steps with the cutters till you get the width you need on your rabbet. After that is done you go for the max. depth and smoothing the cut. I use the drop shape cutter for this. Note use the thickness of the last use cone for this job. In my case a 1,2 mm. drop shape cutter.
And this one is one of my favourite cutters, you can move this one for and backwards in the rabbet line.
Finish of with a piece of sandpaper to smooth it out.
End result:
View attachment 360610View attachment 360611View attachment 360612View attachment 360613
When I'm done on both sides I show you the end result.
Thanks for visiting my build report.
Thanks Jim.I like it! Learn and make it. This is the perfect routine.
Thanks Bryan, nice to see you around here.Thats looking great.![]()
Thanks Tobias, we learn from eachother. Always nice when someone shows how it was done. I don't have much money to spend, so always searching to cheap sources. I could buy a brass pipe and make the irons out of them. But this was in my drawer lying around.Very nice result, Stephen. Very interesting manufacture of your rudder hanger fittings. Good work
Thanks ConstNZ for visiting and your kind words. I'm Glad, I could share my findings here and be helpfull to improve ourselfs.Thank you for that tutorial. I always learn much from you and your excellent and ingenious work. Cheers
Pintle! Nice word.Hi Stephan,
It looks great. I was already suprized you put on the lower pintle already. This as you still have to add the planking first and the lower pintle will be positioned on top of this.
I see you removed it again.
Ouch...this should hurt unless the plywood is really relatively thin. I also remember all the tools I was using since I started my hobby. The knife I made myself from a commercial hacksaw, is still with me. I don't use it those days. In Russia, we called that type of knife - kosyachock. I removed the electric tape used as the handle, it was very old and sticky.I remember cutting parts out of plywood with a Stanley knife.
Looks like a kiridashi. I like this one.Ouch...this should hurt unless the plywood is really relatively thin. I also remember all the tools I was using since I started my hobby. The knife I made myself from a commercial hacksaw, is still with me. I don't use it those days. In Russia, we called that type of knife - kosyachock. I removed the electric tape used as the handle, it was very old and sticky.
Guess today, you have a plethora of knives to choose from, styles, and sizes. Below is my 'Kosyachok'
That a nice beautiful fully functional rudder, Stephan. After cutting and carving, you are now also a metal-worker!Thanks for the nice comments, likes and visit to my build log
At one moment you succeeded to hang the rudder on the keel. This was a lot of work, precise and educating to do. And fun...
Enjoy the pictures
View attachment 362150View attachment 362151View attachment 362152View attachment 362153
Thanks Nigel for your visit, all the likes and nice comment.Very,very nice work Stephan !
Being unfamiliar with Dutch ship design, I have one question. On the horizontal keel Scarphs, are the three horizontal bolts in the join designed to act in the same way a hooked Scarph would work? By that, I mean reduce sheer stress on the joints vertical bolts
Kind Regards
Nigel
Hi Johann, thanks for visiting my build report and the kind words. To receive a compliment from a talented builder like you is always a great moment. Which only strengthens the motivation to continue.Hi Stephan,
a very interesting and instructive construction report.
Also a very precise and neat work.
Thanks for sharing.
Hi Nigel,Very,very nice work Stephan !
Kind Regards
Nigel
Hi Nigel,
These are not bolts or treenails but plugs.
As Stephan said these are used to close the scarph joint from water seeping in.
In the scraph joint holes were drilled, these were stuffed with moss. Then the holes were plugged with small round kegs. The moss expanded and the scarph joint is closed avoinding seepage through the joints.
