- Nov 30, 2022
Thanks to you allowing me to publish my photos
**VIEW THREAD HERE** |
I think it's great that you are willing to share your work. Your input as helped to keep me pointed in the right direction.Thanks to you allowing me to publish my photos
Tutto il modellismo è un mega puzzle, dipende dal punto di vistaPraticamente è un mega puzzle 3d con minimi aggiustamenti qua e là... Non credo che mi possa dare soddisfazione...pensiero personale..
……and, I add, a lot of knowledge of modeling otherwise you don't even know where to get your hands on. Let's make it clear that it's not a LEGO.Above posts translated.
(It's practically a mega 3d puzzle with minimal adjustments here and there... I don't think it can give me satisfaction ... personal thought ..)
(All modeling is a mega puzzle, it depends on the point of view)
I have to agree with @giocomail , all models are Mega Puzzles, some more than others. All the parts for this kit may be precut but they need a LOT of preparation before finally being placed.
Jan
Let's not underestimate how hard some Lego builds can be……and, I add, a lot of knowledge of modeling otherwise you don't even know where to get your hands on. Let's make it clear that it's not a LEGO.
absolutely not, especially the technical onesLet's not underestimate how hard some Lego builds can be![]()
Beautiful
….Hmmmm May the force be with you Jan…
That was a little bit of trial and error getting everything fit (no Pavel cheat sheet in box fort his kit).Fancy stand... and good job, Jan!
Once you become an expert on this kit, you will release your own 'cheat sheet', then should help others.That was a little bit of trial and error getting everything fit (no Pavel cheat sheet in box fort his kit).
Jan
Good point, that is why I showed the solution I worked out. The parts look interchangeable but are not. The final test was a complete dry fit.Once you become an expert on this kit, you will release your own 'cheat sheet', then should help others.
I have to admit this build is a lot of fun to work on. I enjoy having to work out the various build steps. As I've mentioned its a head scratcher at times, but I like how everything comes together eventually.Beautifull progress Jan, i love this puzzle that you are working on
