Hello Tony,
Again a stupid question from my side: have some doubts what is de diameter of the fore mast?
gr
Marc
gr
Marc
Hi Marc.Hello Tony,
gr
Marc
MarcHey Tony,
Yes, I copied your idea for the Waterways and it works so wonderwel! Briljant idea from you!
The idea is to have an exact reference point to place the vertical slats on.
After all, if you place individual planks between the Bulkhaeds, you will have slight differences in heights, which can influence the outdoor planking.
I will try to produce a plank 1/8" x 5/16" and bending the shape of each Bulkhead... I will try and see if it to do.
I'll come back to you.
Hi BillPlan, Mockup, Measure as many times needed to alleviate hesitation, saw once - ASSEMBLE! Just that easy, lolNo wonder it takes a year or more to complete a build! Great work - sound process Tony!!!
Thanks for the reply glad that this is helpful to you, looking forward to seeing your builds in the future.GREAT!!! MOST helpful!!!! FYI - I have been saving these logs as PDF files and saving them as I build my models. Having to save them on a detachable memory. For all, the skills and techniques are super files to have and use on almost any model. SUPER work and THANKS!!!
Hi MarcHello Tony,
I came to the same conclusion: spacer of 1/8" under the waterway and gluing the top gunway rails...
But prefab the dummy gunports is again a great idea...
I'll try it out...
PS
I have already broken five (5 !!!!!) bulkhead extensions.
I'm very very carefully but the slightest touch is enough to break them!
Fortunately, I was able to fit the broken pieces back in perfectly with CA glue every time....
I therefore enforced them with a layer of CA glue....it helps....
And yes, there is a lot off thickness variation!
Tony,
The reason why I mentioned the 1/8 was that I indeed ended up with 2 different sizes. And yes, sheet 2 is confusing. I checked everything twice and indeed you are right: it is 3/16.....![]()
Hi MarcYes, I always worked in the metric system..... an error happens fast.....
Hi MarcHi Tony,
Would like to get your opinion:
On sheet 2, just beside the counter block, they have drawn a gun box but whit one side against Bulkhead R.
If my measurements are right, we should NOT place an wouden part additionally to the R.. see photo included from a blog on another website below....
See also photo sheet 2...
PS
Work in progress....
