- Oct 9, 2020
Wow. This beast is turning out to be more complicated than I thought it would be. A challenge! One question that I have is whether the supplied lumber is adequate to complete the model?
Hi Marc & everyone else looking in.Dear Tony,
I would like to receive your opinion...(and everybody off course...):
for installation between Bulkheads K-R (because Bulkhead extension are 1/16"
1 - installation of the main rail eg strip of 1/16 x 5/64 at 7/16" above planksheer(s). strip bleu colour
2 - Gluing a plywood piece of 1/16" thick which fit perfectly between bulkhead extension and main rail becoming total width of 1/8" (without the outside strip)
for the parts between E-K other plywood thickness (I have several sizes which fit between) and the same for A-E
Advantages:
-Plywood easy to install and can easily being fit to the right sizes...
-Almost no sanding.....
Hi JackWow. This beast is turning out to be more complicated than I thought it would be. A challenge! One question that I have is whether the supplied lumber is adequate to complete the model?
As a result of this discussion, I decided to purchase the tutorial by Bob Hunt. It appears to mention what lumber is required. I am hoping this will address that issue. Worst case scenario I guess I would need to buy more lumber.Hi Jack
A big problem is the drawings show timber thickness but not the width, I'm forever wondering if I'm using the right stock. It's impossible to know at this stage if there is enough timber other than the material list checked out OK. I'll keep you posted.
Tony
I have seen a few logs with builders using this tutorial, I would be interested to have your opinion.As a result of this discussion, I decided to purchase the tutorial by Bob Hunt. It appears to mention what lumber is required. I am hoping this will address that issue. Worst case scenario I guess I would need to buy more lumber.
certainly.I have seen a few logs with builders using this tutorial, I would be interested to have your opinion.
Tony
Looks good I wish I could build as quickly as you do.Hello Tony,
I'm implementing your plan B...
Peace of cake.... I can only recommend to use plywood...
I'm using a strip as reference in order to position the plywood strips in the correct angle (eg these of the Bulkhead extensions).
I also use plywood of two different thicknesses: eg 1/16" and 3/32 which fir perfectly between the Bulkheads....
The plywood has being cut on a height of 7/16"....the height of the gunports or distance between planksheer (glued on top of the waterway) and bottom of main rail...
Easy.
I am in the same boat as you. I have to get everything online. It is a hit and miss sometimes, but usually it works out ok. It's just the shipping costs that are outrageous.Looks good I wish I could build as quickly as you do.
Having just moved interstate I have not found a good hobby shop or anywhere I can get suitable materials from (with timber I like to see what I'm buying. I'm often disappointed with some of the stuff I get online) so I'll try to use the materials that are included in the kit.
It's going to be very interesting and helpful to others to see how these methods progress.
Tony
There's plenty of timber included with this kit.My neighbor built this kit. He and I frequently discussed the merits of various manufacturers, but he never mentioned having to buy additional material. I - for one - appreciate when manufacturers include more material than is needed. The addition of a few extra planks makes a big difference in my satisfaction with a build and my overall impression of the quality of a kit (and manufacturer).
i like your setup. everything has it's own place.There's plenty of timber included with this kit.
Modelexpo has a good reputation for replacing/supplying additional parts so I can't see why there would be a shortage of material. There's suggestions on the drawings for a bit of bashing that would require additional parts.
It's only when the model is complete you can make a proper judgement.
Tony
IMO, I would say it's well worth the cost. I find the instructions that come with the kit lacking in detail and the plans a little confusing. The tutorial seems to fill this gap. He presents things in step by step fashion and describes what lumber is required in detail. I can't see myself building this ship without the tutorial because I am not really a scratch builder. More comments to follow when I start building the ship which is several months down the road.I have seen a few logs with builders using this tutorial, I would be interested to have your opinion.
Tony
Nice lumber rack. I have thought about doing something similar with a cardboard box. Can you stand it on end to same bench space?There's plenty of timber included with this kit.
Tony
Hi MarcMay I come back to the theme of wood supplied with the kit?
As I said, it is still too early to judge the amount of wood supplied.
And not meant negatively at all...
I think the kit is a real challenge...perfect: what I was looking for.
And as Tony put it perfectly, the plans tell you what to do, not how to do it.
Anyway I have already bought a quantity of wood:
- strips /8 x 1/8 inch - l=40": I use these as reference strip placed over the length of the hull to be able to place nicely connecting strips later.
- strips of 1/8 thick and 7/16 wide, length 40" : I needed these to be able to place the dummy gunports without having to fiddle too much.
and few others...
I like the creativity that this kit allows, and I find this platform the perfect conversation partners to ask for advice, learn and get ideas.
PS
I'm already toying with the idea of providing the deck with a thin sheet of plywood and covering it with high quality wood such as Tanganyika strips... But first I'll find out what the deck is actually made of...
