     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Thanks for the kind words. Hope to see you at either the workshop meeting or the club meeting. The workshop is tomorrow morning but I’m heading out and won’t be there. I do expect to be at the club meeting on 8/19.HughLo, The comment I want to make is - Your symmetry of your stanchions looks great in the overhead photos, along with the nibbing is visually striking. Great work!
BTW - I'm going to try to make a couple of the club meetings up in Denver here soon.
Thanks for the recommendation. Got a week away from the BN which gives me some time to decide and order.Lee Valley.View attachment 388045
Beautiful time-tested tool! And enough weight to let the plane do the work - best part, Stanley planes are easy to find on Ebay - except a #1This is a Stanley 6 1/2" long overall (6" shoe) block plane about 40+ years old. It is a multipurpose plane, just the right size and weight to use with one or two hands and easy to control. It has all the features a block plane MUST have: depth of cut control and fine adjustment for the throat in the toe. It comes apart and reassembles easily and has a nice, hardened carbon steel blade, that sharpens easily and holds an edge. I don't know what it costs anymore or even if Stanley still makes exactly the same plane. But it has all the features and utility you want in a block plane and will last forever. I've even dropped it on my concrete basement floor a couple of times with no apparent ill effect, although I wouldn't recommend it.
PeteView attachment 388184View attachment 388185
I used a plane on my Bluenose. I use a small Stanley that is about 3x1 inch at the base.Thanks for the tip. Is there a good one or ones you (or anyone out there) recommend?
Is it easy to use a full-sized plane on a 3/32” plank board? I’ve never used a plane. Would you recommend a beginner use a “full-sized” one (like your Stanley) or go with a small/miniature one?This is a Stanley 6 1/2" long overall (6" shoe) block plane about 40+ years old. It is a multipurpose plane, just the right size and weight to use with one or two hands and easy to control. It has all the features a block plane MUST have: depth of cut control and fine adjustment for the throat in the toe. It comes apart and reassembles easily and has a nice, hardened carbon steel blade that sharpens easily and holds an edge. I don't know what it costs anymore or even if Stanley still makes exactly the same plane. But it has all the features and utility you want in a block plane and will last forever. I've even dropped it on my concrete basement floor a couple of times with no apparent ill effect, although I wouldn't recommend it.
 As for releasing the tape you can do that with a little lacquer thinner on a brush without warping or damaging the plank. The thinner shouldn't (in theory) raise the wood grain. But that's all neither here nor there since you've got it done. Looks pretty cool!
. I had success planing 2 strips at a time while held in a clamp-on vise. I think the small Stanley plane I used likely had more control of the cutting depth than using a chisel-type blade would of had. The 2 strips helped support each other and add a bit more rigidity while planing. It also had the benefit of keeping the taper fairly even on port and starboard sides of the deck as I used one strip on each side.8/14 to 8/24
While I was in Vallarta I decided that instead of using a plane for tapering the planks on the quarterdeck, I would use a nice 4” drill press clamp and an exacto knife. My reasoning was that in order to use the plane, I’d need to first clamp the plank in something. So at this point, why buy two things when I can get a good clamp and use my existing blades. The clamp was at home when I returned.
The clamp was bigger and heavier than I had expected but I believe those are good qualities in what I need. The weight will help to keep the clamp in place while the size allows more of the plank to be held in the jaws of the clamp. Since the taper is supposed to be 6” but the clamp face is only 4”, my plan was to use some scrap 1/2” aluminum strips I had to “increase” the clamp face to around 7”.
This idea didn’t work as well as I had hoped for because in order to work, I have to hold both aluminum strips plus my plank (which needs to be at a very slight angle to create the taper) - while tightening the clamp. Just too much.
Then I tried to make a wooded jig that would fit inside the clamp and let the plank sit on top of the jig at the correct angle. This too didn’t work either as it had too much flexibility - after all, I’m only cutting a 3/32” taper. Any flexibility is bad.
What I landed on was to clamp the plank in the jaws at about the correct angle with one end of the plank aligning with the end of the clamp face. I’d then cut away about 3” of the taper and then loosen the clamp and slide the plank so I could taper the other end. Then a little sanding. Not ideal, but it worked and was repeatable.
Long term I may get a set of magnetized 6” clamp jaws to attach to my clamp, but for now I’ll use it as described above and then see how often I need 6” or longer tapers and the 6” clamp jaws.
Installed 8 planks (4 on each side). I believe I’ll need between 8 and 10 more on each side to reach the side of the transom and the nibbing plank. At this point most or all of them will need to be tapered.
Installed 10 more planks, 5 on each side and cut out the hole for the main mast. Unfortunately when I went to drill the beginning of the hole, the drill went into the plank on the starboard side. Argh! I cut a small section out of the damaged plank and glued in a replacement piece. I believe this will be covered by the mast ring and the fife rail, so hopefully it won’t be noticeable.
Installed 4 more tapered planks, 2 on each side. In order to even up the number of planks on each side, I needed to modify the tapers on the starboard planks. For the next 2 planks, only on the starboard side, I made the taper less than the others.
I then glued the nibbing strake on both sides, and wrapped up the day’s work by installing the final tapered plank on each side.
Once the deck is complete, I plan on drawing a line across the ends of the planks on the transom and then cutting off the snagletooth appearance.
Started with the planks that get nibbed. It’s been over a month since I nibbed the foredeck and was hoping to finish the last 1/2 dozen or so planks and close off the quarterdeck but given reality, I was only able to nib one plank on each side before having to tap out as we’re on the road again. This time we’re heading California to visit our daughter who is a (can I say a bad-ass) wildland firefighter who’s working the Smith River Complex fire right at the CA/OR border.
I feel it looks rough but think (okay HOPE) it will look good once I sand it.
Sorry to put the Bluenose back in dry dock, but happy to (okay hopefully) see our daughter (if she can get some R&R). See ya all in about 2 weeks.
Work time: 12 hours
Total work time: 139.5 hours
I admire your commitment to the tappered planks. A deja-vu for me. It is difficult to apply them smoothly as a complete package. You are doing a nice job.8/14 to 8/24
Work time: 12 hours
