- Dec 16, 2016
Hello and welcome. There seems to be quite a little community following me now on this build and all commenting and giving likes, thanks everybody, appreciated.
All is still good with the kit and I can feel that I’m progressing, so today’s episode continues with the ribs. I dry fitted my first rib into the keel, it fitted snugly but I did notice that it wasn’t at 90 degrees, probably only a couple out but it was noticeable, putting a 1mm spacer behind the sternpost moved the keel just enough forward to bring the rib perfectly vertical and subsequent ribs are also at 90 degrees. Given the amount of pieces used in making up the keel I think that only 1mm out is more than acceptable so no issues there. I’ve made up and dry fitted another four ribs, as I mentioned earlier, after the first rib the rest became easier.
Most builders of POF kits comment on the char removal as a downside, I found that the method I adopted was quick, less than ten minutes per rib, easy and created little dust which Mrs Ken appreciated, I’ll do a post on it tomorrow.
