Happy birthday Daniel. Best wishes for a wonderful day celebrating with family and friends.
HAPPY BIRTHDAY Daniel![]()
wish you all the best and happiness
you are doing wonderful work on this model
THANK YOU VERY MUCH !!!!!HAPPY BIRTHDAY Daniel![]()
Thank you Jimsky!!!!Happy Birthday, Daniel!![]()
Thank you Heinrich !!!Very belated BUT a very happy birthday my friend! I hope and pray that there will be many more years ahead in which you can delight us on SOS with your builds!
Good morning Daniel. I’ve been away and had some catching up to do. Wow some serious work done and I missed your birthday. Happy belated birthday. Stunning progress and some fine detailed work. A clever plan to use pear veneer to make the planking to your taste. All looking mighty fine. Cheers GrantHi Guys, here I am with an update after a few days.
First thank you very much for all your comments and likes. Keep them coming
A lot of pictures will be posted. Ask any questions you could have.
The lower section of the mast was added (forgot his name). Comes in 2 pieces that were adapted to the hull.
View attachment 395832View attachment 395833View attachment 395834View attachment 395835View attachment 395836View attachment 395837View attachment 395838
Then I was curious to see how the stern carvings around the window will fit, as many internal sections that soon I will have to built depend on the window/carvings position.
I assemble one carving, but it still need a lot of work to be done. I only did it to visualize the position and space.
A note on this lady carving:
The stern corner carving is huge and complex. It has detail on 3 sides and is very thick in cross section. It was done using Vectric Aspire to slice up the part into different pieces. These pieces are then CNC carved in 3D and glued together like a mini model. This process is called "3D Assembly".
Here the pieces that have been 3D carved into a 3/4" slab of boxwood.
Remember, this carving still needs a LOT of work, from my side, to be perfect before being glued.
View attachment 395844View attachment 395845View attachment 395846View attachment 395847View attachment 395848View attachment 395849
Now that I saw that the carvings fit well, I did a rough window position. The final window opening will come later.
View attachment 395850View attachment 395851View attachment 395852View attachment 395853
This work was followed by the great cabin deck gluing, support pillars added and Quarter deck built (yet not glued).
View attachment 395854View attachment 395855View attachment 395858
That's all for now....
Cheers !!
Daniel
.... Yes a BQ ..... with the Stern wood ... HAHAHAThe Dematos shipyard is cooking! That looks beautiful, Daniel!
Very good progress my friend![]()
Daniel, you are doing very impressive work and beautiful![]()
Nice work Daniel. You are making great progress.
Mike
magnificent carHi All
As always, thank you very much for your comments and the likes !!! , I really appreciate them.
In order to install the wall panels of the Great cabin, I decided to set up the final deck clamps positions of the Quarter and pop deck.
Mike Shanks provided us with measurements taken from the prototype. But, as you already have seen in the SOS Fubbs builts, probably every hull will be unique. Due to that, most of the pices are oversized, to allow them to be shaped to each hull.
To adjust the clamps position to my hull, I built the Great room stair, position the entry facade and the dome. Plus the 3 sections of the pop deck, defined in red on the drawing.
My quarter decks clamps were high. So I unglued them and reposition using the stairs plus a mock up of the entry with the quarter deck planked.
Here are a few pictures.
View attachment 397122View attachment 397123View attachment 397124View attachment 397125View attachment 397126
Now I need to share my free time with my other hobby. Driving my Ford A Tudor 1929. Temps are going down in Florida and is time to do some setup and repairs on it. Finally I was able to have a little order on the new house Garage. The cars (I also have a Mercury 1956) were relocate last September. Since then they were only started a few times. They stayed at my parents house 10 miles away. I drove that distance on a route that has 60 mph top. In Florida, drivers like go fast and my 1929 was flying at 40-45 mph top. I got some not happy looks .... HAHAHA
Cheers to all
Daniel.
