Thanks Paul, it's appreciatedLots of progress Glenn...and impressively done!
Thank you very much Tobias. Yes, a little bump of pride when you upgrade with a little bit of homework and trial and error. I cut 6 of the handle holders and burned through 4 before it looked right. It was great fun.Hi Glenn
very nice and clean work, I like it when you replace parts from a kit with homemade parts. It gives the whole thing a personal touch.
Thank you, encouraging words. I'm having a lot of fun with it.Just catching up on your build log Glenn. Excellent work.![]()
The lighter band is a very nice detail that sets off the rail...In David Antscher's book, he installed a 3/4" thick molding under the planksheer. It was lighter in color. It looked like a great addition and so i set off to implement it. 3/4" at 1:48 is 1/64" and I don't have a thickness sander per say.I designed some pieces for the laser cutter using basswood for the color and tried 1/32", but it was too thick and looked poor. Today I took out a palm sander and ground down a 1/32" sheet to ~1/64" over a course of 30 minutes. It was a bit of an Ahab moment.
Here are some of the cut pieces going in. I can't take this trim fully forward until I install the head work, but i think it gives you a sense of where it's going.
Sounds like it's worth a shot. I'll see what happens with Danish Oil, I think that''s were my finish is heading.I did have to buff out the brass with a #4 fine flat needle file to get the reactivity I wanted, probably the same with a finish on top as well.The lighter band is a very nice detail that sets off the rail...
I once saw someone put a finish on the wood (poly or whatever) and then blacked the brass and there was minimal leaching of the black into the wood. I've never tried this myself, but it might be worth an experiment.
Thanks Grant, just plugging along. I'm close enough that I have a punch list now.Good evening Glen. Wonderful progress. Cheers Grant
