La Candelaria - Occre Build log
Thanks guys. I appreciate the kind words. Still working on 1st layer hull planking & will update that step when completed. Almost done.....Al.
Looking good, but there's something you may want to check before planking further... not a fault of yours. Since I don't know the official part name, I'll post a description over on my build after I go down and grab a few pics.
So the sanding begins. Yes the nails need to be pulled but first I wanted to start at the stern & see how the back plate ( not sure of the correct name for this part) aliens with the planks & bulwarks. A little sanding needed to be done on the bulwarks as well as the planks. From here I'll finish planking the bulwarks, pull the nails & sand,sand & sand. You'll notice I have a block of wood under the quarter deck & clamped to protect the fragile bulwarks while sanding.
I'm in the process of planking the bulwarks & trimming out the ports. I thought about trimming out the ports after I glued the planks in place but found it easier to dry fit the plank over the ports & trace out the holes with a pencil then trim them on my mat. Once glued in place I'll use a fine file to finish them off.
Question......I know what the gun ports are but what is the purpose for the small ports? IMG_6131.jpgIMG_6133.jpg
Question......I know what the gun ports are but what is the purpose for the small ports? View attachment 406971View attachment 406972
I was wondering that myself… only thing I could think of was that they were for oars to maneuver the ship, but no large oars are provisioned for in the kit.
I had two thoughts when I went in… either scratch build some large oars and have them strapped down on the rack that the ship’s boat is on, or delete those ports altogether, which is why I held off on planking the interior of the bulwarks. I wanted to see the look of the ship with just the gun ports cut out on the exterior planking, which is what I’m working on right now.
I guess these smaller ones were used for the oars - so called sweep ports
some smaller ships, like sloops, 20 gunner frigates etc, but also bomb vessel had oars to manouver near the shore
The shown model has the sweep port on the extra deck, but most of the time were two sweep port between the gunports - so the oarmen worked between the guns
For example by Granado, I am working in moment has them also
Excellent explanation Uwek!!! Thank you. Love the models you shown also.
Spent the last 2 days sanding the hull & besides some small touch ups & inspection from various angles I should be done. I actually really enjoyed the sanding process & am amazed by how rock solid the ship feels in my hands.
Isn't that an awesome feeling?? I just finished my sanding last night, and while I can't say I "enjoyed" it as much as you, it certainly wasn't as bad as I was dreading. I'm going to do the planking on the interior of the bulwarks before I proceed with the exterior planking, though.
Something I saw in an older thread... I forget whose it was so I'm sorry I can't give credit, but it was mentioned to stain the first layer from the belt line down with walnut so if you happen to have a small gap in your planks somewhere, the blonde wood underneath won't be shining through like the North Star.
It sure is nice to see it sanded down & faired. Next up is installing the waterways on the inside of the bulwarks then lining the exterior of the bulwarks with sycamore. After that comes the walnut on the hull.
You prepared a very good basis - looking very good
BTW: I love to touch my bodies -> ships hull bodies off course
Thanks Uwek, always nice to get feedback from experienced ship builders.
I'm almost ready for the 2nd planking but first I need to research the correct or best way to lay down those planks. I ordered Planking Techniques for Model Ship Builders by Donald Dressel to help me with this critical step.
