Thanks guys. I appreciate the kind words. Still working on 1st layer hull planking & will update that step when completed. Almost done.....Al.
On my 2nd. ship I plan on cutting the time to 50 hours54 hours ? You think too longSo far, so good.
I'm in the process of planking the bulwarks & trimming out the ports. I thought about trimming out the ports after I glued the planks in place but found it easier to dry fit the plank over the ports & trace out the holes with a pencil then trim them on my mat. Once glued in place I'll use a fine file to finish them off.
Question......I know what the gun ports are but what is the purpose for the small ports? View attachment 406971View attachment 406972
I guess these smaller ones were used for the oars - so called sweep portsI'm in the process of planking the bulwarks & trimming out the ports. I thought about trimming out the ports after I glued the planks in place but found it easier to dry fit the plank over the ports & trace out the holes with a pencil then trim them on my mat. Once glued in place I'll use a fine file to finish them off.
Excellent explanation Uwek!!! Thank you. Love the models you shown also.I guess these smaller ones were used for the oars - so called sweep ports
some smaller ships, like sloops, 20 gunner frigates etc, but also bomb vessel had oars to manouver near the shore
The shown model has the sweep port on the extra deck, but most of the time were two sweep port between the gunports - so the oarmen worked between the guns
For example by Granado, I am working in moment has them also
Spent the last 2 days sanding the hull & besides some small touch ups & inspection from various angles I should be done. I actually really enjoyed the sanding process & am amazed by how rock solid the ship feels in my hands.
It sure is nice to see it sanded down & faired. Next up is installing the waterways on the inside of the bulwarks then lining the exterior of the bulwarks with sycamore. After that comes the walnut on the hull.Isn't that an awesome feeling?? I just finished my sanding last night, and while I can't say I "enjoyed" it as much as you, it certainly wasn't as bad as I was dreading. I'm going to do the planking on the interior of the bulwarks before I proceed with the exterior planking, though.
Something I saw in an older thread... I forget whose it was so I'm sorry I can't give credit, but it was mentioned to stain the first layer from the belt line down with walnut so if you happen to have a small gap in your planks somewhere, the blonde wood underneath won't be shining through like the North Star.
Thanks Uwek, always nice to get feedback from experienced ship builders.You prepared a very good basis - looking very good
BTW: I love to touch my bodies -> ships hull bodies off course
