Thanks Guys for your nice comments
Hi Nigel,Slowly moving along as I have had some chores to do
With the deck trimmed and faired, I have started to fit the ceiling planking between the bulkheads using some 5mm X 1.5mm Birch I have spare from the Soleil Royal.
The instructions have you fitting this later after adding some ply supports for the deck edges. I will not be fitting these supports as they are not needed as my upper deck will have a ply sub base and they do make this area look untidy.
View attachment 411616View attachment 411617View attachment 411618
Hi Nigel,
I have a question: You have not done any tree nails or simulation of them. Is it a question of scale that they might make them not realistic enough? On the deck planking.
I’ve started my Santisma trinidad and your advices are very interesting.
Patrick
Super work, as always Nigel. Is that a #4 blade on your scalpel?A small update in that the large ship's boat's planking is well underway with just 5 strakes per side to fit.
The bow required some severe edge bending which I will cover when I plank the small boat.
View attachment 414553View attachment 414554View attachment 414555
I will list my departure from the kit build so far rather than cover what is the instructions;
