Tell that to John AliprantisI understand that the skeleton is so stiff that it could withstand a bomb explosion.
But why put a bomb with a timer inside, I don't understand. Well done. Kabommm![]()
I understood very well what was going on, I know this case. At the beginning I watched these movies. Now I prefer to be stupider but with knowledge from a less emotional source, with many mistakes and the awareness that someone takes my opinion into account (at least a little, then pours warm urine over it).Tell that to John Aliprantis
and he still will say it's crap
Good evening Nigel. Your work is so inspiring. Besides building incredible ships you share so much technique and advice on the how to. I certainly appreciate this. Cheers GrantFirstly, Happy New Year everyone. I have not been online much over the holidays as I have been focusing on family time but with some building in the stolen hours.
I have been following the instructions, well almostI will list my departure from the kit build so far rather than cover what is the instructions;
Keel drilled to take M4 steel rod that will be used to secure the model to the stand but also provide +ve and -ve for the 12v supply for the lighting
Kit battery tray repurposed to take digital voltage regulator to provide 2.9volt output for the LEDs eliminating resistors- as I side note, I fried two of the flickering LEDs from the light kit soldering the wires on despite using my smaller iron. You MUST use a heatsink between where you are soldering and the LED body. These LEDs contain tiny microchips and they do not like heat.Lesson learned, I will order another kit from AL in Spain, I plan on adding a few extra anyway.
More supports added to the deck beams fore and aft for the next level.
The upper "Bulwarks are being lined with 0.8mm ply from my stash, these will provide a backing for further dummy frame extensions, I do NOT plan on planking these areas but having exposed framing. No plans exist for the ship post refit, I reason as these areas are extensions of the original hull, there is some argument that these were not planked internally. Looking at Artesania's CAD model on You Tube, it is my interpretation that is what they had in mind when designing the kit then took a u-turn deciding to cover these areas with planking inside. If anything, this will add a talking point to the model and differ it from the masses.
Some pictures of where I am up to.I am working on the planking on the Portside at the moment from the waterline up, then I will revert to the Starboard side. I can get away with not working equally on each side now, the skeleton is so rigid it could withstand a bomb blast.No concerns of pulling it out of shape.
One tip for anyone building this model, I made a shaped former to bend the planks. Soaked them in water for two hours and then clamp in the former.Leave overnight to dry out and they keep their shape when released.My former can take four planks at a time speeding the process up slightly.Every build I have seen so far of this kit, including the one in the instructions exhibits some faceting in the transition of radiuses at the bow, ensuring the planks are accurately preshaped seems to have stopped this so far on my model.
View attachment 419375View attachment 419376View attachment 419377View attachment 419378View attachment 419379View attachment 419380View attachment 419381View attachment 419382View attachment 419383View attachment 419384
@NMBROOK Did you skip point 9-27 of the instructions specifically? I wonder if it would be better to fill the floor (at point 4) and only then lay the covering, wouldn't it be nicer ? What is your idea ?
This is one of those models where there will be a lot of difficult questions, some stages are a bit strange.As a small follow on to that question, if anyone has any similar questions do not be afraid to ask.
As I stated at the start, the mission statement to myself was to build some really special from this kit without changing everything or spending an absolute fortune on replacement parts.
The beakhead bulkhead is a good example, improvements in appearance can be made without buying anything, just changing the order of work to that shown in the instructions which is completely free.
There will be many small "tweaks" like this and I do them on the fly and may forget to cover in my text, so once again please ask
Your constructions have always been interesting, you usually make corrections or correct existing mistakes, I like it. New instructions from @Artesania Latina are very detailed and high quality, but in places it is done very chaotically, like a game of ping-pong, a little here, a little there, once the equipment, once deck covering, then some equipment again, back to covering, painting several times, sanding, painting... Finally, it's done correctly, but I don't like this kind of bouncing from bow to stern, with painting middle way. I usually make major corrections and change the order of construction myself. The problem is with people who don't think and do according to the instructions "because that's how it's supposed to be, the instructions say so", then problems arise.
Nigel, are you finding that you have had to correct the sheer on this model - your pictures look sweet and fair - or did AL get that right?
Hi NigelHi Bill
I will check out your build, have you thought about posting a log on here?
I am keeping the changes subtle as overall the kit is pretty good out of the box. From eight feet away it will look stock, the many small changes will only come to light in close scrutiny.
