- Dec 16, 2016
Hi everyone. Today’s update is my bash at raising the quarter deck walls. Yesterday I mentioned that the finished height of the quarter deck walls ended up being obviously too low and looked wrong. The issue arose because the instruction manual only shows a computerised image with no detail, measurements, diagram or guide, the height is determined by the number of planks added, I must have missed a tapered one which raised the rear section to the correct height. I’ve shown a picture of the image given and the number of planks seems to show exactly what I’d done so I don’t know where I went wrong. Not wanting to rip out this section and rebuild it I decided to just add open rails similar to how they are shown in the Anatomy book bringing them up to the correct height.
I cut the uprights from 2mm stock, pinned both ends, sanded off the paint from the fitted walls, measured, cut, then glued and pinned them into place. Using a length of 3mm strip I curved the end then placed it on top of the uprights applying a little glue and then lightly hammered it down onto the pins, I then sealed, sanded and painted it. Although it isn’t correct it’s now much nearer the way shown in the Anatomy book and looks much better than the simplified kit version so I’m rather pleased that I’d made the error, every cloud has a silver lining, so a satisfying day at the shipyard.
