Soleil Royal- Re-engineering Artesania Latina's New Kit by NMBROOK
With respect, I think you need to distribute that additional spacing across the entire battery, otherwise that middle 9-gun section will look odd, as compared with the gun spacing fore and aft of that section.
You can, though, make your hull-length addition in the mid-ship section where the bulkhead profile remains more or less constant.
Ahoy!
HULL AND DECORS FOR MODEL SOLEIL ROYAL
We can design and 3D print hull for SR as per yours (WojtasS) body plan of hull. There is no problem.
Also We can design and 3D print decors as per Tanneron or other drawings also. This is your choice.
Gun barrels for Soleil Royal are ready now.
The scale of the model does not matter. All decoration we design in the scale 1:12 or 1:24. Then just reduce to another scale you need
Always under decors we design the hull. Hulls of sailing ships this are not simple (straight) surfaces as floors in buildings. Decorations must fit tight to the hull.
@DARVIS ARCHITECTVS wrote - It would take more work and expense, but the end result would be worth it…… YES WILL BE EXPENSIVE. :(
The price of the project of all decors and hull to model Soleil Royal is 2000 EURO. If there were 10 willing modelers........ the cost of the project would be 200 Euro per person.
Of course to make this we need TIME About 9-10 Months. :D
Currently we are busy at the designing decors for model Le Fleuron. Initialy we can begin work on decors to model Soleil Royal in March 2024. 3D Printout will be ready earliest in spring the year 2025 ;)
Thanks,
Kris
Ahoy!
Thanks,
Kris
BUT IT WILL BE WORTH IT!
Ahoy!
Thanks,
Kris
If we're talking about Tanneron's version and there will be other modelers participating in this project then yes I'm intrested
My personal opinion is that Tanneron's model is too much of a compromise; it is neither 1669, nor 1689, nor 1693 - with any conviction. Tanneron's model is an amalgamation of these sources. What I like about Nigel's model is that he is more firmly contextualizing his SR between the refit year of 1689, and the second SR of 1693.
Ahoy!
Thanks MarcRedface
That price is good value for money Kris knowing the development work involved. The hard part is getting 10 modellers to agree on what to base the model on...
Happy New Year EveryoneBeerBeer
@NMBROOK - it's mission impossible.
I don't believe I would ever design decors for a Soleil Royal or Sovereign of the Seas models. :-)
But......
HAPPY NEW YEAR
Hello, I discovered this build log thanks to Marc (Hubac historian), and I will follow with great interest ! It's very exciting !
Kind regards,
Marc
Hallo @Nek0
@NMBROOK - sorry for using your topic for the regards and would like also to ask how this project is going? Do you have any updates?
Hello everyone, I thought I had better explain what has been going on in my head.
I kind of feel I am letting all of the 63 members down that are following this thread and yes I know I am one of them.
Last autumn I left my employer to work for a previous one who I had worked for for over 20 years, but this time in the position I always wanted, Workshop Manager, in charge of the whole factory.
Seven months later the firm went into administration resulting in all 70 employees being made redundant. I will not bore you as to the why's but it was clear to me that some very bad commercial decisions had been made by those well above my pay grade.
I am in touch with most of my ex colleagues and fortunately everyone has found alternative employment including myself.
I have been suffering with a loss of self esteem, wondering if I could have prevented it? . Rationally thinking about it, no I could not, nothing short of a magic wand or £3million would have sorted the problem out.
Now I find myself in a position lower down the ladder with the employer I left last autumn. This has been a struggle with my pride initially, however these last few weeks I have been able to realise something missing in my life.
After nearly ten years in management, I finally had a weeks holiday earlier this month when I didn't once think about work, I left it behind at the gate until I went back after my holiday. Not once had I experienced that in all the time I had been in charge. Makes me think I am better of doing what I am doing now.
I found myself thinking about my hobbies and also able to hold proper conversations with my Wife without my mind drifting to work. I HAD MY LIFE BACK!
I was in my localish model shop looking for something small to rekindle the fire. I looked at all sorts but kept being drawn to a completed model of Caldercraft's Imara in a glass case. The whole atmosphere this model exuded was different to anything else I have experienced other than maybe two models I saw as a child. I thought, stuff common sense, I only live once and 30minutes later an Imara kit was in the boot of my car, fortunate they had one in stock, displayed not 10 feet from the finished model in the caseROTF
I need something completely different and something to take me out of my comfort zone forcing me to do extensive research on something I knew nothing about, model steam power. I have spent hours on Youtube and the net learning what is an amazingly interesting subject. I used to tinker with full size cars a lot when I was younger, building engines etc and there is quite a bit of crossover with the mechanical engineering side of things, so it fills a bit of a void left by no longer messing with cars, I do fix mine sometimes when it goes wrong but it doesn't go wrong very often.
So, Soleil Royal and others will be on the back burner whilst I fire through my Imara project. Parking Soleil and Trinidad will allow the enthusiasm for these two builds to build back up again.Happy Hunter also needs completing.
Bit of a story to that. After painting the hull I placed self adhesive foam on the work stand to protect the paint. The solvent in the adhesive lifted the paint off in small patches. I will cover the repair of this when the weather improves as it involves some very careful airbrush work in the workshop. Last thing I need is cold or damp causing issues.
Sorry for the long winded post and yes I will be starting a log on Imara. I have started some initial work but have held of with a log as I had come to a standstill waiting on myself making a decision on propulsion. WellI have ordered TWO PM Research No 8 V twin steam engines today that will power the model.The engines are in kit form as well so I will be building those up and covering in my log. Boiler will have to wait a little for financial reasons as I want the biggest I can practically fit and allow room for the various other items that will service the power train.
Kind Regards
Nigel
