- Jan 10, 2022
Thank you Tobias. Very kind of youHi Keef, very good progress and clean work.
|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
Thank you Daniel. Very good to know you are followingHello Keef, just found your build and am very impressed with your work. I will be delighted to check in on your build from time to time.
Yes, once closed up at the bow, I shall be exactly half way. l love this part of a PoF build. Keeps me amused for weeksstep by step and frame by frame - but I think you can see already the light at the end of the tunnel
Happy framing for some more days
Thank you very much Paul. Yes, the single, double and triple makeup as well as the step down thicknesses of the futtock sections all add to the interest of the framework l thinkThe design is very attractive, isn't it! With the different frame forms and frame combinations there's lots to look at and admire. Nice progress!
Great work Keef. Am I seeing s slight horizontal curve in the keel? Would this effect translate up through the ship?Good afternoon guys. l have now joined the frames from midships to bow. l must say l'm very pleased with the accuracy of this kit as all frames fit perfectly into place after some adjustments and fine tuning where the slots join the keel. The beautiful shape of the hull is now becoming very evident, both inside and out and as the next step is to continue on from midships to stern to close the hull all will be revealed in a few weeks or so. l have said before l find this a fascinating stage in a p.o.f project as the lines and curves of a ship's hull slowly show themselves
Hi Daniel. Thank you for your comments. I have looked closely at these photos and think I see the slight curve in keel that you are referring to. I have checked and can assure you the keel is perfectly straight. It is a distortion caused by the camera lens. You have great eyesight. I'm still not sure that I see the curve or notGreat work Keef. Am I seeing s slight horizontal curve in the keel? Would this effect translate up through the ship?
Thank you Heinrich. I very much appreciate your comments and interestDear Keith. As per usual, your work is exceptionally clean and tidy, and the form is starting to show her beauty. I am sure that the frames will be completed in no time!
Thank you mon ami for you interest and comments. Sorry to be boring but l'm not going anywhere near a saw. l decided before beginning this project to make it a conventional build and not split the hull into two halvesTrès beau travail Keef. Tu fais les deux parties séparables ou tu sépareras ensuite en sciant horizontalement?
Bonne continuation. Tu es sur une très bonne voie de réussite.
April 2022 - appr. the same stageOui. C'est toujours possible.
Yes. It's always possible.
