My first model - caravel "La Niña" 1:72 scratch [COMPLETED BUILD]
Я посмотрел хороший чертеж в 72 масштабе. Там расстояние между ступеньками 4 мм. Я бы еще переделал крышку люка, она сделана не верно и не масштабно.
I have already installed the ladder((And they already told me that the rings on the hatch are too big, I will try to reduce them.
Well, now, at the request of Uwe, I will briefly describe the method for making the stairs.3386719.jpgOn a piece of cardboard I drew two lines at a distance of 10 mm from each other. I put a rope on top of them - a hook holds it on top, a piece of tape on the bottom (by the way, the hook is a temporary measure, then I will remove it).IMG_20240602_100003.jpgI temporarily free the right side of the rope from the tape, then in the right place I slightly unravel the rope and pass a step between the strands.IMG_20240531_172556.jpgI fix the right side back with tape. I do the same with the left side. To secure the step you need to make four safety knots. I'm using python node.
At the beginning of this video they show how to tie this knot. LINK
I soak each knot with liquid superglue, which I take onto the tip of a pin.IMG_20240602_100126.jpgIMG_20240601_142857.jpgAfter this, the excess threads are cut off with a knife.
The remaining steps are made in the same way as the first. In this case, it is very important to maintain the same distance between the steps, measuring it with a ruler. On a large rope ladder, I managed to tie several steps unevenly. This is very bad! I can only hope that it won’t be noticeable behind all the rigging and sails. I also want to say that I did the big staircase a little differently. There were two separate ropes and two hooks.
Лесенку я уже установил(( А мне уже сказали, что кольца на люке великоваты, попробую их уменьшить.
Дело не только в рымах (кольцах), но и в самой конструкции. Грузовые люки не закрывали отдельными досками, в этом нет смысла, а делали один, или, несколько щитов, в зависимости от размера люка. Рымы ставили по углам, круглыми, если крышка тяжёлая и требовались тали с гаками, или треугольными, если подымались вручную (для удобства руки). Отдельными досками закрывались люки с трапами во время шторма, но они были без рымов.
It's not just about the eyes (rings), but also about the design itself. The cargo hatches were not covered with separate boards, this makes no sense, but one or several panels were made, depending on the size of the hatch. The eyes were placed in the corners, round if the lid was heavy and hoists with hooks were required, or triangular if they were lifted manually (for the convenience of the hand). Separate boards were used to cover the hatches with ladders during a storm, but they were without eyelets.
Thanks for the new information. To be honest, I've never heard of this. On many models and drawings I saw that the hatch consists of separate boards... Therefore, I did the same on my model...
Это в основном модели из наборов или сделанные по чертежам из наборов. Посмотрите модели более высокого уровня.
Вячеслав, Уровень качества модели определяет судья на соревнованиях. Мы же, ваши коллеги моделисты, не соревнуемся здесь. Пожалуйста учитывайте разный уровень наших навыков и возможностей. Далеко не все могут создавать свои модели как Дима Шевелев или Игорь Капинос.
Вячеслав, Уровень качества модели назначается судьей на соревнованиях. Мы же, ваши коллеги-моделисты, не соревнуемся здесь. Пожалуйста, оцените разный уровень наших навыков и возможностей. Далеко не все могут создавать свои модели, как Дима Шевелев или Игорь Капинос.
Я не оцениваю модел. У каждого свой уровень. Я́ просто указываю на то что не верно и не логично. А принять это или проигнорировать дело автора модели.
С логичностью или не логичностью трудно спорить, у каждого своя логика. А вот как быть с утверждением верности, если доказательства верности для кораблей 16-17 веков, не говоря уже и более раннего периода судостроения отсутствует или очень скудна? Является ли модель другого моделиста достаточным к утверждению верности?
It is not always so. Here, for example, are drawings from different authorities: Niña from Pastor, Niña from Troppmann, Santa Maria from Mondfeld.Нина.jpgf307t4802p122064n3_PFDZEkqN.jpg30-10620993-mbh-1992-10-0014.jpg
Aprecio muito o seu trabalho, parabéns pela construção da caravela Nina, espero que continue neste hobby e continue construindo outros modelos.
