Well the bow assembly has been kicking my A$$… I have the individual hawse timbers correctly made since they’re exactly per the plans. It’s been the assembly that’s been a challenge. I finally started over and assembled a frame for the timbers.
With this frame the Timbers seem to line up correctly.
This is where I “discovered” the problem that I haven’t seen addressed anywhere. Or if it has been I missed it… anyway the filler pieces are NOT parallel. Adrien’s book simply says to make filler pieces 3.5 x 5 mm and size them according to the plans. Closer inspection of the plans and Visually looking at the Timbers in the construction frame confirms this.
A little geometry of the angles confirms the filler pieces are angled and each are different.
Last step was to setup my mill to mill the filler pieces at the correct angles.
Now I’ll mill the filler pieces and hope it all works out.
More to come later. Now it’s break time.
