HMS Victory by Y.T.- Mamoli - 1:90 scale
I cannot help but boasting that I just picked up Sherline mill and lathe locally for a fraction of price for a new ones. Something in close to a thousand dollars in US money. Metric, as I always wanted. With resettable zero hand wheels. Not brand new but in perfectly working condition. This is not necessarily going to improve my modelling quality but I always wanted to have these tools in my possession. Cheers.
Thanks all for kind words. I really appreciate it. Now I am starting to face a dust problem. How would I keep a dust away while I’m working on the project? You know I am working very slow and a piece of torn plastic bag doesn’t provide much protection. Dust still accumulates. Please help!
I faced a similar issue. I haven't reached this point in my own build log yet, but I can give you a sneak peek of my solution. Initially, I built a frame from wooden beams and sealed it around with liquid glass and a 0.5mm thick plastic film. However, I eventually settled on an entirely glass option. I simply ordered a custom-made aquarium with 4mm thick walls, inverted it, and covered the model. This protects it from dust and humidity. Additionally, I applied a protective film with a UV filter to the glass to shield the model from sunlight. Unfortunately, I can't attach any photos right now, but I believe the description is clear enough to understand the principle. This setup only protects the hull, though. For larger models, you'll need a door in the case since moving a structure of 1.5x1x0.5 meters is nearly impossible! ))))
I was advised that hemp color lanyards on deadeyes is not historically correct. They must be bade black tarred. I was deceived by white lanyards currently installed on real Victory ship. I will have to either replace the lanyards or have them painted black. Anyone tried to paint a polyester ropes black?
Don't give in that easily YT. I know that our eastern European colleagues and those from Russia have forcefully argued these lanyards are part of the fixed rigging and should be tarred - but my research suggests this is far from certain. After all, their purpose is to adjust the tension on the shrouds while underway - so might they be better considered part of the running rigging? Plus, wouldn't a tarred lanyard bind in the deadeyes?
Anyway, just wanted to provide another perspective (and put a huge target on my back :rolleyes:).
I am in synch with Paul's above posts. The black ropes didn't exist e.g. the regular rope was tarred to become black or dark brown in Continental Navy. Also, tarred rope is mostly used on standing (fixed) rigging of all kinds. The running rigging was never tarred, this being said, the shroud's lanyards were adjusted the tension from time to time, therefore considered as 'running' rigging.
However, who said you cannot make them black? It is your model, and you can make what best suits your taste. But... I wouldn't make them pink color, not because I don't like pink. ROTFROTFROTFROTF
Anyone tried to paint a polyester ropes with any success? What type of paint to use so rope still remains flexible?
In a couple of posts I will tell you how and what I dye the threads with. If you have a few days, follow my updates, I will tell you more about it.
I successfully dye Amann and Gutermann threads in the color I need.
Кто-нибудь пытался покрасить полиэфирные веревки с каким-либо успехом? Какой тип краски использовать, чтобы веревка все еще оставалась гибкой?Вставьте в ветку «HMS Victory [1805] 1:79 от серикова. Начнем с Мантуи -> Обновлено с Анатомии Джона Маккея https://shipsofscale.com/sosforums/...ed-with-john-mckays-anatomy.15458/post-407933
The problem also is that these connections will have to be readjusted when upper shrouds are getting tightened. I have no problem to later cut them off and retighten them. But for that they must be not glued neither to catharpins nor to futtock stave.
I think I cracked this problem. The solution is that one end of rope must be tied to the catharpin rope eye. Then rope goes over shroud and futtock stave as many times as required and the end is tied around the bunch. Connection is called lashing and works same way as a lanyard on the shroud deadeyes.
Same as this contemporary guy explains:
