- Dec 3, 2022
The hardest area I found was the stern, I never really took much notice but it's a bit of an odd shape, sort of flat at 45 deg. side on, then concave, then morphing into convex it blends onto the hull.
Turns out that ‘shipshape’ is constantly changing angles in every possible direction! I find it very confusing at times when I’m trying to shape a plank. “So I bend this bit down and twist it clockwise, with a curve inwards and up at the other end?” Then I turn round to my ‘ironing board’ and do everything the opposite way! Sometimes a plank for the port side fits better on the stbd.
Just a few planks around the wire exit on the starboard side, then rough sand to match, and finally fine sand both sides and go from there.
It’s very neat. You’ve done incredibly well for your first time planking. Perhaps it’s the artists eye, seeing clearly.
There’s a couple of long gaps which you could possibly fill with wood instead of filler. I’ve sometimes glued a plank in on its edge in places like that. I’d always rather sand wood than filler because sanding things with two different hardnesses makes it difficult for me to avoid making waves.
When you do a single planked POB or a POF you can’t get away with anything except perfect but seeing what you’re doing already, I think you’ll cope.
