Once again my learning curve has reared his head. I made up.the paper strips and marked them using the planking fan provided me by
@Jimsky followed by marking three central frames with the resulting layout. After four TR al planks I was wildly out from the layout. The planks provided in the kit vary quite a bit.
The only corrective action that comes to mind is to sand down every strip to make room for an additional row of planking. Since this would cancel all the fun from the planking I did a test using full size planks. The result is a partial plank at the keel. Actually looks it might be perfect with a rabbit. (The plans show no rabbits or bearding lines.) The actual number of planking rows from the test are one less than the calculated rows.
Apparently the variance in planking strip widths is significant. I am in no position to complain about the kit as the one I purchased was from an individual and had set on a shelf for mine than ten years
( I have made a second rule for future kits. Only purchase kits verifiably of recent manufacture.)
My bottom line is that I'm going to make new paper strips and layout with the reduced row. My goal of achieving a first plank that would be suitable as finished is modified by allowing the half sized garboard row keeping in mind that the hull gets copper plating.
