As you can see in the photo above, the cockpit metal rail was removed. That rail and stanchions were looking sad, scratched and dull. I needed to find a way to polish the brass  rail and stanchions. Could not find any suggestions here, so I did it "my way". The rail was relatively simple to polish by rubbing it with a clean cloth after repeating the blackening process. The stanchions needed more effort, till I came up with my lazy-man method:
In my research I found two things that I need to consider:
1.  Ships of this vintage did not have metal rails around the cockpit. As this is my first ship, I decided to follow the A.L. plans with this.
2. Hexagonal (head) bolts were not invented till 1830 and not widely available till 1880. So I'll need to make some square head bolts.
The set-up I used for reattaching the cockpit railings, as I hate glue getting on my finished mouldings:
Now waiting for the adhesive to set before removing the stanchion separation masking.
Working on the stern lantern with the electrical (candle) system. According to A.L. I'm supposed to mount this shortly. However, as it is a delicate piece, I'll wait till the chainplates are installed before I permanently attach it. I will use the kit provided lanterns for the tops, but this one will be fitted in the stern.
