- Mar 1, 2022
Fully agree. That's superbe!
it's looks beautifulThanks all, working at such a small scale hides some of the errors. The joiner isn't great on some of these. The alignment also isn't perfect.
There's technically another row that goes on both sides, but I'll probably skip those because that will be planked, not sure yet.
Looking Fantastic! Lovely work.Installed and cleaned up to make the decking more level, well level at the curvature it's supposed to have.
Also installed a few pieces of decking to cover up some of the most unaligned portions.
Might put another deck plank or two in to give some added stability and foundation for the next level.
True stoyLooking Fantastic! Lovely work.
Great progress, nice build. How did you deal with the "notchs" or the join between 90o beams? I'm a beginner and a little confused on how approach this accurately.
I used a flat blade to mark the outside, then I used a Dremel but to bore out the space, and a chisel to square it off.I'm guessing that due to the small size of the beam, you just use a scalpel/chisel to make the notch after positioning and marking.
A thousand thanks for the reply,
cheers,
These are clearly shown for each deck on the original deck and inboard profile drawings. The round up for each deck is given in the contract as well. In the case of Enterprize, there are two sets, one as she was a fighting ship, and another set when she was de-masted and converted to a receiving ship in the Thames, a rather ignominious end to her career IMHO. An example of the upper deck of the original design is below. Note that some of the beams were shifted when built and shown with red linesHow do you know and get the spacing for the beans. Is there a definite measurement ?
Does "rounding" refer to the amount of crown on the beam as measured from the clamp to the centerline? How is this compensated for at the ends of the ship where the hull narrows to keep the deck from bulging up disproportionately?Rounding varied for each deck.
When (ifI am curious to know how accurate the rounding is on the kit plans. NOTE: The platform beams in the hold have no rounding
Hi. How do you know and get the spacing for the beans. Is there a definite measurement ?
Or did you take the measurements from the plan?
