I can tell that you identified the new Airfix kit which makes either variant so you win the prize.
Ooh, goodie! What is it? What is it? I'm quivering in anticipation!![]()
your Anson
Ah, my uncle, after whom I was named, was training in the Royal Flying Corps when war, WWI that is, ended. I have the control knob of an RE2 engraved with the date he crashed it.One thing that was really good about old Airfix instructions was the way they used the correct terms for things. I learned a lot that way, although I never learned how to pronounce ‘pitot’ before Air Force training, much to my embarrassment.![]()
Too right!There's only one way to locate one of those missing parts. I must spend days scratchbuilding a replacement, glue it in place and then seal the fuselage permanently. After that it will only be a matter of moments before my eye falls on the fugitives and I smilingly say "Ah, there you are." (or words to that effect.)
I’d use my time machine to go get them but I lost the keys to it.
They're in the violet tray also.
...so I've put it somewhere safe .
Here we go again.
Your control wheels are quite good smithy!
This would be a good candidate for a resin printer.For a number of reasons I haven't been able to do much creative modelling lately. I'm hoping things will soon pick up because there are some exciting projects in the pipeline and I'm still very keen to make a good job of this one. Funnily enough, every book that I pick up seems to mention the Anson at one point or another. Perhaps that's not surprising given that half my reading materials right now are related to aviation in WWII.
I had a go at scratching a control wheel, first from copper wire and solder and then from plastic card. Neither are brilliant but the plastic one is obviously the most suitable. It will look better painted and it's very small so I think I'll get away with it. I'm not up to painting it today so I've put it somewhere safe .
Of course it has to be modeled and the STL file exported to set up in slicer software to create a print file.
I can model it and export a STL file if you have access to a printer.
