me too.I used FDM maybe one day I'll get a resin printer as the parts will be more detailed. It's the smell and mess that's putting me off.
Tony
I decided to use ropes for the gammoning for various failed attempts at the chainsWork continues with the bowsprit, painted and ready to be installed.
Dry fitted everything looked OK.
I used a string line to align the bowsprit while gluing.
On the original ship the gammon chain is held in place with threaded eye bolts, I'm using thin wire through the chain glued through a hole in the bracket. This proved to be a tricky operation no room to move.
It was only when I had the chains in place and tried to fit the gratings I realised that i had made the brackets to long and I could not fit the gratings or heads.
After a lot of inappropriate language and reworking with the bowsprit in place I successfully attached the chains.
Gratings are a tight fit and had to be cut down to fit, the heads also needed modifications to the drawings.
After all the problems I had with installing the chains I wish they where more visible on the model.
Tony
I considered using rope but could not work out how to fit the steps over the rope,. I tried the rope under, over and inbetween the steps and ended up using the chains.I decided to use ropes for the gammoning for various failed attempts at the chains
I am not really sure yet. I haven't done anything yet. But I know that I won't be able to have two gammonings(is that a word?). Now having said that, I wish that the instructions would have said to do the bowsprit before putting in the rails. Now it's next to impossible for me to double up. I may have a better chance trying the chains again. Sigh here I go again...lolI considered using rope but could not work out how to fit the steps over the rope,. I tried the rope under, over and inbetween the steps and ended up using the chains.
How did you do yours?
Tony
Which ever way you do it it's a pain. If the bowsprit goes in first the rails will be much harder to install.I am not really sure yet. I haven't done anything yet. But I know that I won't be able to have two gammonings(is that a word?). Now having said that, I wish that the instructions would have said to do the bowsprit before putting in the rails. Now it's next to impossible for me to double up. I may have a better chance trying the chains again. Sigh here I go again...lol
I must say, the bow is kicking my butt. I hope it gets easier
that`s what I was afraid of. I am flipflopping between chains and rope.Which ever way you do it it's a pain. If the bowsprit goes in first the rails will be much harder to install.
I attached twisted wire about 2" long to both ends of the chain. Then fed the wire up past the rails through the hole in the bracket and glued it in place..
Tony
