…..fantastic work Peter. It always amazes me how clean and precise your work is. Cheers Grant
Th…. Th…. Th….. Thanks, GrantGood morning Peter. What they all say or ditto,ditto, ditto and ditto
Thanks, Grant. For the most it’s ‘time’, ‘measuring’, ‘tools’ and ‘minor adjustment’ each time. Those inseparably linked to the each other. Most definitely the 4th with the 1st.…..fantastic work Peter. It always amazes me how clean and precise your work is. Cheers Grant
Thanks, Paul. A few planks a day, makes a deck sheet in a …….. month (or two) …..Wonderful, meticulous work, Peter!
indlela entle kakhulu….Peter.A small update to record the progress of the 'off-deck decking'. The sheet can still be removed.
And put back where all deck openings ensure that it's no longer shifts:
At the front, the 1st nibble plank is also glued. With the transition to the 2nd part. There are now 5 complete strokes up to the back.
After the 3 frames around the deck openings, there are now 4 towards the aft deck:
In the curve at the back, the first 7 planks are sawn off in the curve. Then they are also nibbled.
I am now going to lay complete strokes on the back, after which the connections with the middle follow. And I can fill the middle piece up to the side.
I need to get the translation app out, Grant. But I'm definitely on my way to a complete deck.indlela entle kakhulu….Peter.![]()
Hi Peter. It is Xhosa. I have read all the Deon Meyer books except his latest one Leo - also a Benny Griessel story. I got a signed copy for Christmas from the Admiral. He is my favorite author although I’m a little bit biased as he is South African and he rides bikes (a BMW unfortunatelyI need to get the translation app out, Grant. But I'm definitely on my way to a complete deck.
PS: I'm just reading the series of books by Deon Meyer. About Benny Griessel, who works at De Valken / the Hawks Team of the SAPS. In those books also a lot of Xhosa!
) as well. Enjoy. Cheers GrantYou have every right to be ‘biased’, Grant. And so you see, we have a lot in common: longitude degree, ship models, bikes (mountain/motor), (Scottish) Whisky, author with the (only) right choice for a BMW …..Hi Peter. It is Xhosa. I have read all the Deon Meyer books except his latest one Leo - also a Benny Griessel story. I got a signed copy for Christmas from the Admiral. He is my favorite author although I’m a little bit biased as he is South African and he rides bikes (a BMW unfortunately) as well. Enjoy. Cheers Grant
Thanks, Dean. It’s just during the build. I can now press the planks against each other and straight against a steel ruler, upside down to be sure it’s flat, drill the holes for the plugs under the drill press, sand it flat on my workbench. At the end I glue it as a sheet and hopefully with a nice flow of the sheer and deck rounding. Because I now feel that the sheet has flexibility in it. After sanding it will be +\- 1 mm thick.Beautiful work Peter! Will the deck remain removable or is that just while you build it?
Thanks, Jim. Who knows I see some other off-deck decking’s in future build-log’s ……. Just measuring in/on the model and the rest on the workbench. Much easier.Truly outstanding work, Peter. Your attention to detail and precision are both impressive and inspiring.
Thanks for the compliments, Allan. I made the 'plugs' with the regular toothpicks from the supermarket. I also did a test with increasingly thinner strips of beech from the boards, but to get them step by step through the desired opening of the DrawPlate .....VERY nice work! Lots of things to like, but one that I noticed in the last photos is the subtlety of the deck nails/plugs. What material did you use for these faux nails? They look really good.
Yes, I saw your post, Allen. And posted my method right after (#26). It works great for me and I don't have to strip and cut.I have yet to try toothpicks but I know it is popular. I do use my drawplate with the progressive holes down to 0.016 with bamboo as I can make fifty or one hundred with one small bamboo skewer that I split into a dozen strips and cut into individual treenails. If you have not already seen it, the following may be interesting as your method is shown as well as others. https://shipsofscale.com/sosforums/threads/tricks-of-the-trade.15492/page-2 post #25
