HMS Victory of Caldercraft by Wil
30 Making Mast Components
Meanwhile, I’ve started looking into the masts and rigging. There are still quite a few challenges here, like the mizzen topgallant yard, which needs to taper over 49.5 mm from 2.3 mm to 1 mm, with the diameter reduced in proper proportions. I wonder if this will work and stay intact, it’s so thin. But we’ll see.
This week, I started making the wooden mast components. Months ago, I bought a small Proxxon lathe for a bargain. However, the lathe is too short to make some mast parts at full length. Additionally, the 10 mm feed diameter limits me in making the lower sections of the bowsprit, mainmast, and foremast, as these are 12.7 mm at their thickest.
So I disassembled the lathe and mounted the drive and carriage separately on a plank. By moving only the carriage, I can now adapt the machine to any desired length.
For the masts, I created a kind of production sheet, in which I recorded the modeling and measurements. This makes things easier than working from large drawing sheets.
The 12.7 mm dowels from the kit turned out to be slightly warped. Luckily, I still had some old dowels of that size that were straight. After tapering the ends, they were ready to use.
First, all relevant measurements are marked on the dowel, such as transitions from cylindrical to tapered and square. The taper is measured using a standard division.
Next, the wood is tapered with a narrow gouge near the reference marks until nearly the desired thickness. The bottom of this tapered area is darkened with a pencil to remain visible during turning.
After approaching the black lines with chisels and gouges, sanding blocks are used in grits from 80 to 220.
Once the entire dowel is tapered, it’s finished with 240 grit sandpaper. That completes the turning for this mast part.
Above, I showed how I tackle the round tapering of masts. But mast parts also include sections that are square or even octagonal. Here's how I addressed that:
It seemed easiest to perform this while the workpiece is still in the lathe. The key is the position of the nut that drives the chuck. I filed a notch in one corner of the nut, which becomes the reference point to keep track of the rotation.
I made a small template that fits the lathe’s nut, allowing me to rotate the workpiece 90 degrees at a time. In each position, a flat side can be sanded onto the workpiece with a sanding board.
Next, the tapered section where the octagon is needed is turned.
To add the octagonal shape, I made a similar template, but with the nut’s hole rotated 45 degrees.
With the final result:
Yesterday, I turned the last parts on the lathe. I really enjoy this work, but the topgallant masts presented some issues. They’re very thin compared to other parts, and unsurprisingly, I had to remake several of them. They keep breaking just before they're done. Grrr…
True turning with a chisel is limited, it’s more filing and sanding while the piece spins. That causes a lot of wobbling with such long, thin rods. A fixed tailstock isn’t a solution either, because the workpiece is often too thin (about 2 mm) to handle sideways forces.
The best option, in my opinion, is to gently support the end by hand so it can flex slightly. And don’t apply too much pressure with tools. You learn that naturally after starting over a few times.
The photos below give a nice overview of the mast parts that are “finished” so far. From top to bottom: foremast, mainmast, and mizzen.
Good evening Wil. This is fantastic. Thanks for the detailed log as well. Cheers Grant
I meant to mention something. Although this may not be of any use since you are making the yards from wood, whereas my medium is mostly 3D printing, I have had great success strengthening yards with carbon fibre rod and bar as thin as 1mm. If you're able to bore a 1mm hole for most of the dowels length, you could insert a CF rod (glue with superphatic glue) and this will make the yard considerably more stiff for turning to shape. It's possible to buy 100mm long drill bits down to 0.5mm diameter, if you search the web for "extra long micro drill bits"
31 Assembling the Masts
Over the past few weeks, I was able to continue working on the masts. After the turning and filing of the conical, square, and octagonal parts, the lower masts are now finished, including the bowsprit. Then I could begin assembling the various parts onto these mast sections.
Below is an impression of what is currently on the workbench.
On the ship, it looks like this.
Sharp-eyed viewers will notice that the eccentric bulges for the bowsprit’s seizings are still much too thick. These were not easy to make. I clamped a 12 mm dowel tightly into a hardwood plank, drilled some off-center holes, and then enlarged them to 12.5 mm. What remained were eccentric shell sections that are now on the bowsprit. These will be neatly sanded into shape using the disk sander.
Continuing with the lower masts and the first section of the bowsprit. Structurally, these are mostly complete. What’s still missing are a few eye bolts.
I’ll check everything again before painting this section.
32 The Tops
Since I was already working on the masts, I moved on to the tops. Love this part of the process. First, I cut all the pieces, deburred them, and did a dry fit. The drawing looks like this.
To properly place all the beams on the tops, I transferred everything from the drawing to tracing paper and marked the positions on the wood.
After adding all the beams, it looked like this.
Once all protruding parts were removed and the cross trees glued in place, the next picture was taken. Don’t worry, the trestletrees aren’t glued yet.
Once the glue had dried, I couldn’t wait to hang the tops on the masts. I first glued one trestletree to each mast and made sure it faced the correct direction (horizontal toward the keel). Once that glue had dried, I glued the other trestletree, using the position of the top to determine placement and alignment.
This was the result. And yes, the tops can still be removed later.
32 The Tops
Good morning Wil. Looking very impressive. Your tops are fantastic. Cheers Grant
Hello Wil, your DB250 'mod', gave me inspiration to do something with mine. I unscrewed the headstock, then remounted it using only the first two screws, extending the bed by 80mm. I do have a bigger wood lathe for bigger jobs, so this was a worthwhile mod. Thanks for the idea!
Stuart
