Amerigo Vespucci 1:84 by Panart/Mantua Build – RC Enabled
Mainsail Winch
Making some good progress. I installed the mainsail winch in a similar fashion as the spanker. The mainsail winch will act directly on the midship sheets, with the forward and aft sheets following.
So far it does not appear that the running line wants to jump the winch drum... should it become an issue, I'll have to figure out a method to tension the lines.
Semplicemente impressionante il lavoro (anzi il capolavoro) che stai facendo.
E' per me un vero piacere aver letto le fasi di costruzione, le foto e i video.
Vederla in acqua è una soddisfazione immensa. Il primo traguardo è centrato in pieno, sei bravissimo.
Impressionante come hai manovrato le vele, hai fatto diventare semplice una faccenda molto complicata.
La prossima volta farò come hai fatto tu, è molto meglio.
The work you're doing is simply impressive (actually, a masterpiece).
It's been a real pleasure for me to read about the construction phases, photos, and videos.
Seeing it in the water is immensely satisfying.
You've achieved your first goal, you're brilliant.
The way you handled the sails was impressive; you made a very complicated task seem simple.
Next time I'll do as you did; it's much better.
You’re very kind with your praise… thank you.
These drum winches make the work much easier. For the spinnaker, I plan to use another drum winch, however this time I think I’ll fabricate my own winch at half diameter. That way it should be easier to conceal, yet still provide sufficient travel.
I have great admiration for all the model builders on SoS who have the patience to fabricate all the deck accessories and details these models call for. I’ve spent the last few days fabricating tiny little tables and benches… and frankly… it drives me crazy!
I would much rather focus my time on propulsion systems and functional sail control. However, I entered this project knowing that much of my time would be spent with tiny brushes and files. So, while I make the deck fixtures, I’m also jumping ahead to the masts, yards, braces, etc.
As I get closer to the next set of sea-trials, I’ve done more research into ‘ballast’ considerations. And what I learned has me a little worried. I learned that the heeling and righting moments is not linear in scale sailboats. In fact, I read that for a 1/100th scale model, the heeling moment is reduced by 1/1000, and the righting moment by 1/10,000. Plus, there’s the ‘crabbing’ issue that these hulls are subject to.
Crabbing (when the ship slips sideways due to side winds), can be addressed with sailing skills.
Heeling and righting is another matter. No one wants to capsize their new model. And even though this hull showed encouraging righting characterises in the bathtub, real life conditions may not be as positive when your carrying 20-wet sails.
To that end, stability risks can be reduced by:
-Sailing on calm days.
-Lowering the sail center of pressure by only using sheets closer to the deck. This of course comes at the expense of speed.
-Reduce the overall number of sails.
-And lastly, add an external fin and ballast. I really do not want to implement this option. It looks odd, makes ship launching a challenge, and introduces a potential leak risk.
This model shows very generous freeboard, so I can easily add much more ballast if required.
Of course, this concern will only reveal itself during full-sail sea trials.
(Here’s another short vid demonstrating my rigging for the three masts. Simple, yet functional)
Sei molto gentile con i tuoi complimenti... grazie.
Questi winch a tamburo semplificano notevolmente il lavoro. Per lo spinnaker, ho intenzione di usare un altro winch a tamburo, ma questa volta credo che ne costruirò uno mio a metà diametro. In questo modo sarà più facile da nascondere, pur garantendo una corsa sufficiente.
Nutro una grande ammirazione per tutti i modellisti di SoS che hanno la pazienza di realizzare tutti gli accessori e i dettagli di coperta che questi modelli richiedono. Ho passato gli ultimi giorni a costruire minuscoli tavolini e panche... e sinceramente... mi fa impazzire!
Preferirei di gran lunga concentrarmi sui sistemi di propulsione e sul controllo funzionale delle vele. Tuttavia, ho iniziato questo progetto sapendo che avrei dedicato gran parte del mio tempo a pennelli e lime. Quindi, mentre realizzo le attrezzature di coperta, sto anche passando ad alberi, pennoni, bracci, ecc.
Con l'avvicinarsi delle prossime prove in mare, ho approfondito le considerazioni sulla "zavorra". E quello che ho imparato mi preoccupa un po'. Ho scoperto che i momenti di sbandamento e raddrizzamento non sono lineari nelle barche a vela in scala. Infatti, ho letto che per un modello in scala 1/100, il momento di sbandamento si riduce di 1/1000 e quello di raddrizzamento di 1/10.000. Inoltre, c'è il problema del "crabbing" a cui sono soggetti questi scafi.
Il "crabbing" (quando la nave scivola lateralmente a causa dei venti laterali) può essere risolto con le abilità veliche.
Sbandamento e raddrizzamento sono un'altra questione. Nessuno vuole capovolgere il proprio nuovo modello. E anche se questo scafo ha mostrato caratteristiche di raddrizzamento incoraggianti nella vasca da bagno, le condizioni reali potrebbero non essere così favorevoli quando si trasportano vele bagnate.
A tal fine, i rischi per la stabilità possono essere ridotti:
-Navigare in giornate calme.
-Abbassare il centro di pressione velica utilizzando solo scotte più vicine al ponte. Questo ovviamente va a scapito della velocità.
- Ridurre il numero complessivo di vele.
- Infine, aggiungere una pinna esterna e una zavorra. Non voglio assolutamente implementare questa opzione. Ha un aspetto anomalo, rende il varo della nave una sfida e introduce un potenziale rischio di perdite.
Questo modello mostra un bordo libero molto generoso, quindi posso facilmente aggiungere molta più zavorra se necessario.
Naturalmente, questo problema si manifesterà solo durante le prove in mare a vela intera.
(Ecco un altro breve video che mostra il mio sartiame per i tre alberi. Semplice, ma funzionale)
Spinnaker Winch
The spinnaker winch is proving to be a challenge. I needed to fabricate a special horizontal servo winch mount, and replace the OEM winch drum with a smaller spool.
Some of you will notice that I used a sewing machine bobbin for this winch drum. I sleeved the bobbin ID with a carbon fiber tube, and drilled it open to 5mm to fit the servo drive gear.
Although the bobbin is half the OEM drive diameter, it still provides 200mm (8-inches) of line travel. More than enough for the spinnaker.
Bowsprit
Who would have thought that the bowsprit would have posed such a challenge.
As much as I would have preferred to assemble the kit bowsprit in accordance with the plans, it had become obvious that the kit materials for the bowsprit, although very scale-like, were not up to the rigours of sailing. Plus, it became apparent that the ship would not fit in my car (or the Vespucci wagon) with the bowsprit in place.
To that end, I am currently mocking-up a more robust bowsprit that could be easily removed from the prow during transportation, and then re-installed at the pond without tools.
The 3mm dowel Flying Jib boom was replaced with a carbon fiber tube, plus a 2mm carbon fiber rod was inserted into the base of the Jib Boom to add rigidity.
Both the wood dowel striker and the yards will be replaced with equivalent functional brass and stainless units.
In addition, a brass tube (9.5mm ID) is bonded into the ship prow to allow the bowsprit to be inserted and then locked into place using functional jibstays.
The bowsprit tension lines will be secured with ‘bowsies’ (on order) which will allow me to assemble the unit pond-site with little fuss.
I've completed the aft deck structure which I believe is the Communication / Navigation building.
It has been modified such that it also doubles as a structure to conceal the deck access opening to the rudder steering-servo motor.
As with the main sail servo winch, the structure is held in place with a magnet, and positioned with a snug fitting centering block.
Next step is to build a suitable cover/hatch for the aft spanker servo winch.
Spanker Servo Motor Hatch
Spent a leisurely Sunday fabricating an access hatch for the Spanker servo-motor. As before, held in place with a couple of magnets.
One more hatch to fabricate for the tiller opening and we're ready to move onto the masts.
Tiller Hatch Cover
Just completed the tiller hatch cover. Still needs a quick varnish...as soon as the rain stops.
With the RC gear sealed and concealed, next is to complete the bowsprit over the next couple of days, then on to the Foremast.
Bowsprit Tensioned
My materials order has arrived allowing me to complete the Bowsprit tensioning. At some later stage, I'll install all the decorative chains and ropes that the ship calls for. However with the installation of these shrouds, the bowsprit can now support the loads expected from the jibs and foremast.
The rigging is anchored with hooks and clips allowing easy pond-side assembly.
Those considering an RC conversion can source most fittings from Sailsetc in the UK:
Does anyone know what this aft-end structure is called?
It's been a while since I toured the ship, but I'm very certain that structure near the stern is the wheel house. The other structure, near the bow, I think was the communications room. We weren't allowed in, but through the windows, I just saw some radios and monitoring equipment.
I actually looked into it just now. I was right, that rear structure is a wheel house, but is specifically called the manuel stern rudder station, which houses 4 wheels that the crew uses the manually control the rudder. There is another wheel located at the bridge of the bow, but this one uses hydraulic assistance to steer the ship.
Makes sense.... I revisited the regulations and this is what I learned:
According to SOLAS Chapter II-1, Regulation 29, ships of 100 gross tons and above, and all passenger ships regardless of tonnage, must have a main and an auxiliary steering gear system. The main steering gear must be capable of turning the rudder from 35° on one side to 30° on the other in not more than 28 seconds at maximum service speed, and it must be operable from the bridge under normal conditions. The auxiliary steering gear must be independent of the main system, capable of steering the ship at navigable speeds, and brought into operation within 45 seconds of a main system failure.
Jib Winch Servo Control
The jib winch setup has by far been the most challenging of the three sail control winch servos.
I sourced a transitional deck pulley component from JP Sails out of the UK that offers an elegant solution to the winch/deck rigging transition.
I’m not entirely happy with the model of winch servo I used for the jibs (Amazon special) as it cycles through its travel range on power-up… none of the other winch servos I used on this model do that! I’ll see if I can still source a superior sail winch through HobbyKing. Failing that, I believe Hitec still offers a sail winch servo…. all be it at premium prices.
With this task out of the way, I can now continue with the fabrication of the mast and yards, whose assembly is handicapped by the horrible documentation provided with this model. Fortunately, we can thank Gilbert for his excellent AV build-log which has proven itself invaluable.
Vid:
View attachment 568158View attachment 568159
Vid:
Impressive
Well done
Foremast Progress
The foremast assembly is coming along...all be it slowly. Thank goodness for Gilbert's assembly thread which offers an excellent resource.
Given that this will be a functional ship, the masts require stays that can be tensioned. For that I utilized materials and techniques that I've utilized for my IOM builds. Utilizing adjustable turnbuckles and stainless stay wire, I am am able to tension the mast, and in turn the bowsprit.
I've located a source for mini brass style turnbuckles that I will give consideration to using to replace these stainless units to better fit with the ship style.
A couple of pics....
Fore Main Yard Pivot Detail
My focus has now moved to the yard pivot detail. For the foremast main-yard, I reinforced the yard with a brass ring, then soldered a .8mm brass rod to form the pivot point with the mast.
Time will tell if it's robust enough to survive use. Should it fail, I'll replace the brass wire with a tempered stainless steel wire.
Note that each yard will have a different mounting detail. Sadly, the kit plans provide little to no detail how this attachment point should be arranged.
I welcome your input in this matter.
