HMS Victory of Caldercraft by Wil
From now on, this build log on SOS will run in sync with my work.
In post 158 Stephan rightly pointed out to me that I had suspended one boat from a stay tackle, which logically of course cannot happen in reality. This would result in excessive tension in the stays. In addition, there is of course the obstruction that in this way the boat cannot be hung alongside the ship.
Stephan wouldn’t be Stephan if he didn’t come up with a solution, and he referred me to the book by Harland. A very specialist book on rigging, which I did not know. Just before our vacation I still got to work on the tackles for a bit.
The question of how the boats should be put overboard has occupied me for quite some time. But the Caldercraft manual says absolutely nothing about this. Even Longridge and McKay provide no real clarity. Perhaps this has to do with the fact that tackles do not belong to the fixed rope functions, but were only rigged when needed and cleared away again after use.
However, the book by Harland provided the solution, and I soon found a drawing in Zu Mondfeld showing how everything could be realized. I have executed the diagram on page 271 twice, in mirror image.
In the photo below it can be seen how it ultimately turned out. In the background the two tackles, which are attached to the main stay. In the foreground, in mirror image, the two stay tackles with which the boats can be put overboard and heavy loads can be hoisted on board. When the yards are added later, two more lines will be added from the end of the yard to the eye splices at the bottom of the little triangles. With these two lines the lateral movements are ultimately achieved.
I think this is how it should be, I am very satisfied.
Almost Wil, the drawing shows it, but a little further on there is also text with an explanation. It is the side tackles that is used. See red encircled. The ones you first attached to the masthead before the shrouds. In conjunction with the yard tackles. One to move the boat outwards and one on the other side of the yard to keep the yard horizontal as a counterweight.
These side tackles are the same rope/cable used for the shrouds and only used to lift heavy loads. Or to secure the mast when the weather is rough.
I looked at Steel, Lees, and elsewhere and cannot find a clear explanation on how the boats were launched. I looked in the Textbook of Seamanship which has great drawings but it is late 19th century so may not apply. https://maritime.org/doc/luce/index.php
Will there be the lines to the yards after the yards are in place? If you or anyone else has a link to a clear description on how these were launched, including when derricks came into use, this would be interesting to see. In the meantime, the hunt goes on.......
Thanks Wil
Some translations of English to Dutch Wil. I think that the mistake is the translation.
Stagtakel in Dutch is the Garnet tackle in English
Zijtakel in Dutch is the stay or side tackle in English. That is difficult to understand which one Harland discribes. So when Harland write about the stay tackle he is talking about in Dutch "de zijtakels" and not about the garnet tackle (Dutch Stagtakel) The burtons are the hangers on the mizzen mast and are also stay tackles (side tackles of zijtakels) Took me almost 2 days to see this too.
For Alan, buy you a copy of the book of Harland, Leest and Harland are 2 books the fit together. Harland was on sailing ships and studied the way how things where done. Fantastic book to read. See attachment where I put the 3 pages about the tackles and hoisting of a boat.
Otherwise see this discussion
THANK YOU STEPHAN!!
