HMS Alert [1777] 1:48 POF by serikoff. (Two hulls: skeleton and fully rigged)
Metalworking. Galvanizing.
Rudder Hinges.
As I mentioned earlier, I'll be making extended loops that extend onto the boards to strengthen the connection. The top loop will also wrap around the handlebars, and there will be another piece to hold the chain in place for an emergency turn if the main steering mechanism is damaged (the red version, not the blue one).
I've previously shown that I modeled these hinges in Blender 3D and 3D printed them. This is in the relevant section.
After printing, I lightly sanded them with 400-grit sandpaper and matched them to the wood. The final fit will be after copper plating.
The holes are more like marker holes, as after copper plating, they'll need to be drilled to the correct size for the bolts.
The top hinge will be disassembled, as it's curved and impossible to install without separating. However, the seam will be inside, deep and invisible.
When everything was ready, I glued the leg holders to the parts. (I mostly use 0.5 mm brass wire, since I have a lot of it. But in the places where the axis will be on the hinge, I use 0.6 mm copper!!! And this holder will serve as the axis. In the rest of the places, I glued the holders inside the surfaces.)
Then I connected all the holders into the wood and covered it all with Graphite Varnish.
The next day I put the first batch into a special copper plating machine for galvanization (I talk about this in detail here).
Looking ahead, I want to clarify that I conducted a lot of testing and experimentation to achieve the best result. This batch was quite good, but there were a couple of defects, and I fixed them when I made the second batch with two more sets of hinges. So, in fact, I now have three sets for my two hulls and one custom-made for a friend. I compared my hinges with the ones in the kit and realized that the latter wouldn't fit on the model and would have to remake the rudder and sternpost for the first hull (although I thought I'd use them like the hinges from the kit, but changed my mind).
I'll describe all the details of the galvanic process and all the parameters in the dedicated thread, but here I'll show the results of the first batch.
The copper layer on the plastic is over 60 microns thick, up to 100, so it's more than enough to sand and polish the copper (I'll detail the failures in the Galvanic section). Two parts were damaged, but I've already repaired them (more on that later).
First, I cut the holder with wire cutters, then sanded it with a file, then went over the surface with 600-1000-grit sandpaper to smooth it out. Then I drilled the holes for the bolts and finally polished it (not too hard, just superficially) with 00 or 000-grit steel wool. Just to remove the sandpaper scratches. Don't polish too much (especially with 0000+ steel wool), as the blackening will adhere less well. I was quite happy with the result, but I felt I could do better and made two more sets. More on that later. For now, here's the result of my first attempt:
Tomorrow I'll try to post something on the Electroplating Tests thread, detailing what I did the first time and the second time... and it looks like I'm finally close to the ideal electroplating method... but I'm not sure... I'm still in the process.
Rudder Hinges.
Zuerst habe ich die Halterung mit einem Seitenschneider durchtrennt, dann mit einer Feile geschliffen und anschließend mit 1000er-Schleifpapier geglättet. Danach habe ich die Löcher für die Schrauben gebohrt und die Halterung schließlich (nicht zu stark, nur oberflächlich) mit Stahlwolle der Körnung 00 oder 000 poliert, um die Schleifspuren zu entfernen. Man sollte nicht zu stark polieren (vor allem nicht mit Stahlwolle der Körnung 0000 oder höher), da die Schwärzung sonst nicht so gut haftet. Ich war mit dem Ergebnis recht zufrieden, wollte es aber noch besser machen und habe zwei weitere Sets angefertigt. Mehr dazu später. Hier ist nun das Ergebnis meines ersten Versuchs:
Morgen werde ich versuchen, etwas im Thread „Galvanisierungstests“ zu posten und detailliert zu beschreiben, was ich beim ersten und zweiten Mal gemacht habe… und es sieht so aus, als ob ich der idealen Galvanisierungsmethode endlich nahe gekommen bin… aber ich bin mir nicht sicher… ich bin noch mittendrin.
Die Ruderscharniere sehen super realistisch aus. Kein Vergleich mit den dem Bausatz beigelegten Scharniere. Der Prozess des Beschichtens ist genial und absolut präzise erklärt. Sergey es ist schade, daß Du kein Bausatzhersteller bist. Dein Baubericht ist die Bibel des Modellbaus auf höchstem Niveau. Danke daß Du uns an jedem Schritt teilnehmen läßt und alles so tief erklärst.
Rudder Hinges.
Wow!
Friends, thank you for your comments.
I've shown the results of my previous galvanic work, but for those interested in the technical details, here you go:
Beim ersten Lesen deines Berichtes ist man einfach nur sprachlos. Die Fülle an Hinweisen, Tipps und genialer Lösungen sind überwältigend. Beim zweiten Lesen erkennt man deine präzise Vorgehensweise. Beim dritten Lesen wird die Motivation geweckt,es Dir gleich zu tun. Deine Arbeit motiviert und zeigt einen ganz anderen Weg zu einem wunderschönen Modell. Du zeigst Wege, die einem normalen verschloßen sind. Nachvollziehbar, sehr gut Schritt für Schritt erklärt. Sehr lehrreich dein Bericht und die Einzelergebnisse sprechen für sich. Danke fürs Zeigen.
