Titanic Trumpeter 1/200 by InkMot
Building the Display Base​
For my display base, I was inspired by Peter Davies-Garner’s book, “RMS Titanic: A Model Maker’s Manual”. In it, he states:
I chose an oak plank which I cut to 5’ (153cm) in length and added molding on all sides. I finished it with tung oil.
View attachment 617021View attachment 617018​
I used a track saw to cut the oak board to length. A regular circular saw would’ve been fine, but I wanted to make sure that my corners were perfectly square so that my trim miters would look clean.
View attachment 617020View attachment 617017View attachment 617023​
Lot’s of sanding: 60g/120g/220g/320g to make it smoooth. I like Osmo Polyx-Oil for projects like this. It wipes on with a cloth and preserves the feel of the oak.
View attachment 617022View attachment 617014
I taped several blank sheets of paper together to trace the shape of the hull, which I reduced to groups of strip lengths. Using the template, I marked out the locations for each strip length on the oak board. The strips (“blocks”) were made from 1/4” (7cm) poplar and cut to length using a small miter saw. Each was glued to the base using Gorilla wood glue and spaced using a scrap strip as a spacer.
Eventually, after much cutting and gluing, you get something like this.
Mounting the Hull on the Base​
The hull was attached to the base using three (3) No 8, brass wood screws. One screw is amidships with the other two spaced 10” forward and 10” aft, along the centerline.
I inserted a short strip in the space between the mounted strips to provide mounting points for the hull and to drill the pilot hole through from the top. This helped later to locate the hole when I drilled another pilot hull from beneath up into the hull and countersunk the hole.
The model was carefully centered fore and aft and left to right on the base. I then held it in place using painter’s tape and a 25lb dumbbell. This arrangement kept things steady while I drilled pilot holes up into the hull from the bottom and then drove the screws.
One of the brass, counter-sunk screws holding the model to the base.
View attachment 617011View attachment 617013
I’m satisfied with the result. Now that the model is mounted, I can proceed with installing the propellers and the boat deck structures. Of course, moving now involves carrying the entire base and ship assembly, but at least the model has more protection.
Great Work!
With the 3D printed funnels, are you going to drill in holes from the stays?
The drydock method looks great on your Titanic. Its the same plan I will use on my 1:350 Titanic when I get to that point. I haven't thought about the layout yet, but your method looks great and I will probably use it when I get there. Thank you for the inspiration on you build
Pete
Great Work!
Pete
Thanks!
I’m still researching the material I’ll eventually use for the stays. I’ll likely secure whatever I choose using a dot of CA. The material of the 3D funnels is brittle and would not likely allow for a clean hole. Also, at 1/200 scale, any hole I’d drill would equate to a foot or more in diameter in scale.
I found that laying out the strips for the cribbing to be more trial and error. You’ll need to place your hull on them while they’re loose to see what looks best to you. For example, you can do a gradual tapering of length along the hull or you can opt to change sizes in groups like I did. I spent months pondering my decision. ;)
Thanks!
Thanks for the info.
Yup I was wondering about the brittleness of the funnels. I considered seeing if clipped fishhooks (the eyelets would be reserved and used) for stays. That way I could use a very small drill bit to make a pin hole for the eyelet to attach to the funnel and use that as my stay anchor point. But then you run into the brittleness issue again.
looking forward to your solution
Pete
I'll probably use the PE shakes that came with my KA detail kit.
You can see a video of Ben at the Midwest Model Shop installing his here:
Navigation Bridge (Part 2)​
Whereby I (some may say) unnecessarily add more detail to the roof of the bridge and assemble the side walls, etc.
The Titanic's Navigation Bridge had beams supporting its roof that ran transversely. There were also larger supports running fore and aft with two support columns. Since the bridge is open on either side - even with the side walls installed, I felt this would make a nice touch.
Here's a nice rendering from Titanic Honor and Glory
I bult my beams with styrene strips. The support columns are brass rods. I added glazing and frames to all of the windows and inserted the PE interior wall details from the MK1 detail kit.
Navigation Bridge in place with side walls installed. The ceiling beams can be seen...if you look. ;-)
Compass Platform​
I used the platform from the MK1 PE detail kit combined with the support legs from the Trumpeter kit to create my compass platform. The 3D-printed MK1 platform was much more accurate while the Trumpeter stock support legs were thinner and closer to scale than the MK1 3D-printed legs. The access ladder came from the MK1 PE.
The Trumpeter support legs are on the left, the MK1 legs are on the right. While the MK1 legs had more detail, they are twice as thick as they should be. I figured that the scale of the legs was more important that the inclusion of a few ridges, etc.
Together, they make a nice pair.
Here is the compass platform in place on the Boat Deck. Note the staircase and compass binnacle are installed.
Funnel Details​
There are several areas of detail work that are required for the funnels. I elected to go with the Model Monkey (MM) 3D-printed funnels (see more information about this here: https://shipsofscale.com/sosforums/threads/titanic-trumpeter-1-200-by-inkmot.13004/post-494192). The MM funnels already include a lot of detail, specifically the pulleys mounted on the top rim that support the climbing rigging needed for funnel maintenance. While the MK1 kit provided these pulleys in PE, they seemed out of scale to me and redundant to the MM pulleys. Plus, and this is more important, I am lazy. So, no PE pulleys. This leaves the build out of the forward maintenance platform, access ladder and the pad eyes for the funnel stays.
This photo shows the MK1 PE maintenance platform in place (sorry, no build photos) and the steam whistles mounted. The steam whistles are included with the MM funnels.
I used the access ladders from the MK1 PE and folded the sides in, rather than leave them flat. I think this is more to scale. I built a cradle for each funnel to rest in while I added details (right photo). This prevented damage and made mounting the tiny PE parts easier.
The funnel stay pad eyes have been glued in place and painted with black enamel for more support. The funnel stay PE parts will connect here and run to the Boat Deck. @PeteG
After all of the details were installed on each funnel, the funnels were secured to the deck using E6000 cement and a couple of drops of CA. This was so that I could adjust the funnels after placing them to ensure that they were aligned. I'm still not completely satisfied and I'll likely move Funnel 1 a tiny bit before installing the stays.
Boat Deck Details​
I've been slowly working my way aft, installing railings, awning supports, ventilators, benches, and collapsible boats A and B, etc. It's been slow-going. A key milestone to starting this detail work was mounting the funnels. You don't want to be threading the funnels around deck details.
Each deck house had to get hand rails installed and painted. Here's an examples of the hand rail work. Each one of these structures was glued to the deck with good 'ol Tester's model cement and a bunch of heavy weight (I use steel 3-2-1 blocks).
The awning supports over the officer's quarters were pretty finicky to install. The vertical stanchions are painted white and the connecting cable is black. I still need to adjust the forward stanchion on the port side. (sigh)
After installing the railings and ventilators, etc. on the Officer's quarters roof, I was able to paint up the collapsible boats (MK1 detail) and mount them on their PE stands with PE tie-downs. This was more work than you'd think.
Moving aft, I've begun installing more ventilators (note that they all have grills made of PE installed, several ventilators are in two parts. All of the ventilators are mounted on PE plates, painted a dark grey. Railings are installed alongside of this work.
Note the first set of MK1 benches in place. My first two were a learning experience. You form them from flat PE, using the template on the lower right of the photo. You then add a center support and the two end pieces with hand rests. The trick is to get them all aligned so that the bench sits level and square, which is quite a struggle. ;-)
All of this detail work in the center of the Boat Deck needs to be completed so that I can add the funnel stays and then move to the lifeboats.
Anyway, here's where I'm at as of 27 September, 2026
View attachment 639557View attachment 639558
Fantastic detail. I plan to do the same thing for 1/350 scale, however, I am making sure that it doesn’t become cluttered.
Funnel Details​
View attachment 639568View attachment 639569
Nice Man!!
I will look to see if they have the same for 1/350 at MM
Boat Deck Details​
View attachment 639577View attachment 639578
View attachment 639571View attachment 639570
View attachment 639575View attachment 639576
Did you see my post last month on building benches, the one thing that I found was sitting the bench on its back with the bottom exposed on its side. Then I can slide the center legs up its spot with using the table as a support and a guide.
