+Since we’re on the subject of CNC, why are so many kits laser cut, not CNC? Is the equipment for CNC more expensive than for laser cutting? Is CNC impractical for mass production?
The following is the original words of the developer. I suggest you go to YOU TUBE to see the CNC and laser cut video.
‘The machining time of the same part CNC machining is about 7~8 times that of laser processing, and it is also necessary to increase the time for fixing the wood board. Therefore, choose to use CNC machining. 1. The original structure of the hull is restored to the maximum extent and handles complex shapes. Laser processing cannot do this. 2, can retain the wood color to the greatest extent, we use different tools and processing methods to process different parts. We cut the original state after cutting it in the photo, not after cleaning.’
