Hey Mike, nice clean woodwork its looking fantastic
Thanks Zoly. I appreciate the work Mike, Donnie and yourself do. I hope more people take advantage of these builds.another awesome Blandford build,nice work Mike!!
Thanks Jim. The hinges are made of 2mm wide brass strip. I wrapped the strip around a piece of 1/32 brass rod. Solder on the joint and cut rod to length. I have a staking tool I use for clock work that I used to make dimples to simulate bolts on the hinge. I tried to blacken them but it didn't turn out very well. I cleaned the brass with steel wool and used a degreaser on them but the black wouldn't take, so I painted with a gun metal black. I think they turned out ok fo faux hinges.Veery niccccccccccccccccce, Mike. Can you tell us how you made hinges? Is it brass?
Thanks, Mie for sharing with us your techniquehe hinges are made of 2mm wide brass strip. I wrapped the strip around a piece of 1/32 brass rod. Solder on the joint and cut rod to length. I have a staking tool I use for clock work that I used to make dimples to simulate bolts on the hinge. I tried to blacken them but it didn't turn out very well. I cleaned the brass with steel wool and used a degreaser on them but the black wouldn't take, so I painted with a gunmetal black. I think they turned out ok for faux hinges.
Thanks for this info Mike as I plan to get into scratch big time. Next crucial investment is a nice thicknes planer. Any pointers from the guys on brands and model types would be very welcome.Hi Mike,
You are off to a fine start; the frames look very nice. I always must adjust the sawtooth type jigs to make things work right. I normally use a gantry jig but since this is an introductory project, I felt like a basic jig would be best to use. If you decide to continue scratch building, you should consider a gantry system. I posted some info on the type I use.
https://shipsofscale.com/sosforums/threads/building-board-gantry-type.1331/#post-21091
Mike
