In addition to Mike's and Christian's advice, If you need to remove more material use the most outer disc surface. However, if you need jus to fine-tune the shape of your frame - use the surface close to the center of the disk sander.
THANKS ALL GUYS GOOD TIPS, WHEN I AM SADING THE ANGLES I MOVE THE PIECE FROM CENTER TO OUTSIDE EDGE (LEFT) IS THIS CORRECT. Don
hi all, as i said in yesterdays post still making frames if i do say so coming along OK showing pictures of recent frames and would love to here from anyone WITH COMMENTS AND CRITISIMS PLEASE, also having a questions for GILLES OR OTHERS showing plans for starting frame 25 trough 32 asking if the center piece is split, please comments. Don
HERE IS THE PICTURE OF THE PLANS WITH MY QUESTION. Don
hi all well i did the V SECTIONS AS SUPOSED TO BE DONE (I THINK) pictures showing how i did it, the overall first layer is correct in its placement, after verifying the placement i removed the floor timber and very carefully scribed the dotted line with a marking knife and an exacto blade several times then using my JAPANESSE SAWS THE VERY FINE DOZUKI to start my cuts unfortunaly it is to small to go very far but CREATES a good start then follow up with my other JAPANESE SAW being very careful have to be ver, very, careful how you position the timber in the vice the final cut is the vertical one with the dozuki and finally dry fitting the pieces together, hope this is correct, again comments and critisismsView attachment 138973View attachment 138974
