Galilee Boat 16” [COMPLETED BUILD]
Looks like you have some burns on the inside of the bow planks. Is that from your plank bender?
The hull looks very nice! ;)
Actually, I don't have a plank bender. I used a soldering iron. That area will be covered by a deck above, a slat deck running the length of the boat, and ballast.
Later I found that soaking the frames for a day and bending them with my finger worked better with no scorching and no breaking of frames.
Great observation, Vic, also if you want to avoid waiting for a day, you can put the material under HOT water and try bending with your fingers little by little. Yet another method is a steam box.
Ready for ribs. View attachment 355999
It’s hard to believe that it represents a month’s worth of work.
Good morning Vic. You are making some serious progress here. The month’s challenge with your twist and turning planks has certainly paid dividends. You owned it.
I placed the frames a little closer together in the middle because it needs more support there to keep from imploding. View attachment 356621
Great work Vic. Looking awesome. BTW what is “disc golf”?
Cheers Grant
