HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Many Thanks to @pianoforte , @Steef66 , @Mirek , @KurtFink , @Ken , @Corsair and @GrantTyler for your kind words and comments and also for all the likes received - I like it very much to get comments and try to answer all the question, especially if I do know the answer - or to give my try to answer, also and maybe especially when there is some additional research necessary.
Dear Grant,
somehow, the use of wooden treenails, or bolts (circular or rectangle, in iron or copper) on my model(s) is off course somehow my personal taste, but also based on some knowledge from different publications. And this "knowledge" is grown over the years with the different models
My Granado model is following as much as possible the given informations by Peter Goodwin in his Anatomy of Ships series
so let us take a first look here - in some sketches are some iron bolts shown (photos taken from my hard-disc of my PC - there are more in the book)
for the frames and the keelson
for the keel
View attachment 449004 View attachment 449005
also the mast foots
View attachment 449013 View attachment 449014
Bowsprit step
View attachment 449018 View attachment 449019
lodging and hanging knees + beam arms connections
View attachment 449016 View attachment 449017
I am pretty sure, that there is also something visible or written about using bolts for the wales and / or the inner thick stuff
But I think, that all structural elements with some specific thickness were connected with metal / iron bolts and not with wooden treenails - they can not be made so long
slightly contrary about the construction of frames (especially related to chock connections) is written in Laverys book - here he is writing "bolts and trennals"
View attachment 449020 View attachment 449021 View attachment 449022
View attachment 449023 View attachment 449024 View attachment 449025
View attachment 449026View attachment 449027
Good morning Uwek. Thank you for this response. It is much appreciated. I wanted to build the HMS Enterprise 1:48 POF as my next model, however there is some legal challenges with this kit and not available. In the meantime I will read some so I start to understand these ships more. Cheers Grant
Yes - definitely helpful - often I mix them up
and the third one very helpful is the Lees
It may be time to invest in buying some books... :D
Yes - these three books are helping a lot to understand the structure and the "working" of english ships
-> very helpful (especially the Lavery and the Goodwin) when you start with POF models
for french ships I recommend the Volume 1 to 3 of Jean Boudriot series of the 74 gun ship - you can find book reviews also here in SOS
that's the one I'm waiting for too, from Modelship Dockyard. :)
I should specify that it's the next one I'm looking to purchase. I'll probably build something else between now and building the Enterprise.
Jeff
That is a true story. I have the art of rigging which I used like 10% of when building my Victory, now it is time to understand the structure and how these ships are put together. Thanks again Uwek. Cheers Grant
Today I would like to give an overview of the lower hull segment - mor or less finished with all necessary interior features and elements - the next will be the treatment of the frames with CLOU
Tomorrow is a public holiday here in Austria so I hope be able to stay some hours in the workshop ......
Many Thanks for your interest .... to be continued
Uwe,
before you start with Clou, you should remove the wooden "pins" on the bottom of the keel. These are only necessary to fix the keel in the jig.
I still keep them, because they are protecting the keel against some damages - the keel can be "Clou-ed" also later
Most impressed Uwe. Have a nice day off working on your ship.
Have a question what is CLOU?
CLOU
available in central Europe - it is wood sanding primer and here in our region often used instead of oil or other wood treatments
CLOU
Ok yes, we have a similar product over here that I use for my carvings. that is called Feast Watson Sanding Sealer and is very good to use as it dries quickly and when you sand over with sandpaper it finishes well. Always have it on hand. Very similar to the Dope we used on model airplane wings in the day.
For most of my models, I use French polish and then finish with wax. However, I have done carvings and models with French polish only. Now, I do use a brush and paint it on. This way I can get the finish I want. I will begin a prelude to my build of the Bounty showing some of the models I have made. I find French Polish is so much quicker to use as its drying times are fantastically quick.
Absolutely love the way the cutaway allow us all to see so clearly, what is usually hidden deep below other decks! The work you are doing on the details gives us all new insights and views of critical structure and construction methods.
Thanks for sharing such wonderful pictures of this unique, educational and awesomely crafted masterpiece!
Hi Uwek,
Just a question about this magnificent model with all the nails used, were they brass or copper?
Also another question. each nail, a hole was drilled?
Gary
