Hi @trussben,Beautiful work.
Would the shot locker hinges not be on top of the cross beam, instead of vertical on the front face? As per TFFM.
Gorgeous innovative work, which I have come to expect of paul.Next, I needed to drill holes for the bolts that would hold the straps to the rudder and the hull. To that end I made a little jig:
I then used epoxy to add the pins to the pintles (I could have soldered these pins but that would have required a lower melting temperature solder (than I had used previously) and I doubted I could pull that off):
That done, I burnished/blackened the parts and completed the rudder side of the transaction:
And just in case you think this was a linear experience...I learned that brass can melt...and that it's possible to solder the pins you are using to hold pieces into place onto (inside) the parts you are soldering...
I feel blessed that you would visit on occasion!
Paul, great idea. I will take it into service, with your permissionI mentioned in an earlier post that I wanted to take a shot at fabricating rudder hinges (pintles and gudgeons). The kit instructions called for a combination of plastic for the hinge parts and black paper/card stock for the straps. On the Vasa I make some faux hinges out of brass shim stock, but they were a pretty weak attempt.
Of course, fabricating actual hinges would mean that I needed to learn how to solder. Not exactly neurosurgery but my experience with soldering was limited to home repair/electronics.
My approach required adding brass bar stock (1.5 mm x 2.0 mm) to some thinner brass stock that would form the straps (1.5 mm x 0.3 mm).
I then did some preliminary shaping:
At this point I felt like I had something to work with...
From me, you get a OK!. Looks very nice, Paul.As prompted by friends on the forum I have added some details to the well house (bolts on the hinges and nails/treenails on the boards):
Yes, the bolts on the hinges are not straight - but since I had to do these freehand (having neglected to include them originally) this was the best I could do.
I am still uncertain if I should be adding 'fasteners' on these build-out elements (there are a lot of walls and such to be added). I struggled adding these nails to the well house (they are 0.40 mm drilled holes filled with wood filler). I can't make wooden pegs small enough. But I wanted to at least try.
Your thoughts?
And for these hinges, you do not get only a OK, it also a WOW, Paul. A nice piece of small construction and soldering.Next, I needed to drill holes for the bolts that would hold the straps to the rudder and the hull. To that end I made a little jig:
Hello Michael,Gorgeous innovative work, which I have come to expect of paul.
Can I ask please
1: What is the jig fixation device used to hold the wood and parts for drilling?
2: After you soldered the pintles how did you shape and polish them? The solder joins are invisible!
3: You mention burnishing the brass. Is this blackening with Brass Black or similar?
4: What is your burnishing method/recipe with the brass to avoid the powder like coating?
Thank you for your detailed post, and the how-to pearls for the ludidtes like myself to elevate our skills.
Satisfied consumer of your eye candy.
michael
