La Créole 1827 by archjofo - Scale 1/48 - French corvette
What is the name of this tool and where can I find one?
dsc01178-jpg.371454
@Mirek
Thanks for the positive affirmation.
I would also like to thank you for the many LIKES.
Continued: Equipment of the big yard - Blocks for buntlines and clewlines - Poulies de cargue fond et poulies de bouline
According to the relevant table in the monograph, the blocks for the buntlines and clewlines are only 3.4 mm long and 1.3 mm thick at a scale of 1:48. With this block size, the sheaves with a thickness of d= 0.5 mm are not used separately, but worked out. In total I need 12 blocks for the main yard and fore yard.
Before I start "series production", I made a "prototype" in the usual way and equipped it with a served strop. The eye is used to attach to the jackstay.
In the following image I have shown different block types and sizes compared to a block for a buntlines.
The next picture shows how these blocks are attached to the jackstay by means of tying.
Sequel follows …
@pianoforte
Hello Adi,
Thank you for your nice comment. I'm glad you like it.
@ConsNZ
Hello,
Thank you very much for your tip, but this does not work with these needles.
On the one hand they are apparently too thick, on the other hand the hole is not an advantage for what I do with it.
I've been getting along very well with my self-made marlin spikes from a cannula ø 1.2 mm and ø 0.8 mm for a long time.
I can't add anything clever my jaw only drops lower and lower after each build-log update. Great craftsmanship and a source of inspirations
@pianoforte
Hello Adi,
@ConsNZ
Hello,
View attachment 372940 View attachment 372941
I was referring to these used by my daughter for her needle work. I'm sure they could be modified somewhat by those of us with lesser skills... BTW Wonderful work you are doing. Most enjoyable.
We talk about a marlin spike, but that is a little incorrect. A marlin spike is actually a big needle without sharp point. Used to separate the strands. You can use a normal needle for this in modelbuilding. Just un-sharpen the tip.
The cannula Johann is using, is based on a Swedish Fid or Dragonspike, a hollow marlin spike.
Here is a video where you can see the difference between them
When you work on a little scale you will discover that Johann is right about the fact that a needle will not work and a cannula does. I tried both and a cannula is perfect in this case because you keep the shape in your rope. With a needle you have to tear the strands to much from eachother to get the rope between the strands.
Sorry Johan to break in your log.
ahhh! now I understand clearly. This answer is very much appreciated as is the video link further explaining the difference [Swedish fid/Dragonspike] I'm familiar with a Marlin Spike as one was given to me several decades ago but I've never heard of a DragonSpike. Steef66 your knowledge, tuition and selflessness in passing on all and any information you've accumulated over the years is simply outstanding and a credit to your persona. Kudos to you. Cheers.
I am catching up my "Today in Naval History"-topic and found, that the Creole was launched at th 5th May (sorry, that I am 3 days too late)
Today in Naval History - Naval / Maritime Events in History
5 May 1829 – Launch of French Créole, a 24-gun Créole-class corvette of the French Navy
@ConsNZ
@Uwek
@Tobias
Thank you for your interest and the nice posts.
Continued: Equipment of the main yard - Blocks for buntlines and clewlines - Poulies de cargue fond et poulies de bouline
In the meantime I have made 12 blocks l = 3.4 mm for the blocks for buntlines and clewlines of the lower yards. I tried to make the seizing as small as possible, which wasn't easy with this size.
These blocks were moored to jackstay as shown in the following images.
I will make my model of the La Créole without the sails, as I have already mentioned several times, analogous to the Paris model. Nevertheless, I would like to attach the arrangement for the clews of the lower sails. These rigging elements are not shown on the original model, so the sheets, tacks and clewlines with the necessary blocks are missing.
At the moment I'm still researching whether single or double tacks were used at La Créole. It still needs to be clarified how the fore tacks were led to the mooring cleats, as there is no information on this in the monograph. There is also another question, whether the French also use cable-laid ropes for the tack ropes?
Up soon …
