Na dann viel Spass beim fräsen diese komplexen Teils
I wish you a lot of fun with milling this complex element
Nicht sehr inkognito, das Paket.
a good decisionA quick review about the Scheppach and the Jet Spindlesander (in German)
Be careful with the rough sanding drums - it goes sometimes very fast when you use too much pressure - upps and you have a dent (Delle) in your frame.Its a lot to sand, i tested one frame. There will be dust !!!
The vac is connectable. Its Arsch auf Eimer, but it fits. A problem is to work with the angle of the table. If you have to use tha backside of the table, the clearence to the wall on´t enough. Because the big frames. But its simple to move the stand 10-20 cm. A simple thing.
I bought now 60er and 80er grid to get a faster result.
