@dockattner …Paul, I considered making raised panels to go in the inset areas. First, they would not be square due to the radii in the corners where the columns are, not a big deal. Second, I don’t have a veneer sheet to make them from that has small enough wood grain for scale. This means I would have to glue boards together. Which is an option, but the walls are currently glued in place and deck sheets glued down. Adding to it now would be much more difficult, but not impossible.
And finally there are some crests or emblems that go on the inset areas. So who knows?
@RDN1954 …Johan, scope creep is the name of the game! When putting on the deck sheets I realized one of the openings for the stairs only had a beam on one side. So I framed it out. Every step of the way I see things I need to add…
